MESH with RUT976 and RUT271
Hello, I tried to configure my Mesh between RUT976 as Gateway and RUT271 as Node like the Wiki shows. After configuration it will works a small time, but i got lost very fast the acess to both routers via LAN Cable or Wifi. I have to reset it to get access again.
Can somebody help me or explain exactly how to configre it?
The last time i lost the access to 192.168.2.1 was after editing the mesh and add the RSSI threshold to -80. after that i got no chace to aceess the device RUT976 and i dont find it with IP Scanner.
Hello @Levin,
To better understand what might be causing the issue, could you please confirm the following:
  • Are both the gateway and node configured within the same network subnet?
  • Is the DHCP server disabled on the node?
  • Additionally, which firmware versions are both devices currently running?
After successfully configuring the mesh network, to ensure all settings are correctly applied, reboot both devices and recheck it.
For your reference, a wireless mesh configuration example is available on the wiki page here:
Wireless Mesh configuration example - Teltonika Networks Wiki, with which, as I assume, you are already familiar.
Let me know whether the issue still persists and additional assistance is required.
