Memory consumption of ledman in xxx_00.07.06.8
In the new 00.07.06.8 release, ledman is consuming more memory over time. When I restarted ledman with “/etc/init.d/ledman restart,” its memory consumption returned to normal. The image below shows the overall memory consumption from an RUTX50, and I have the same problem with TRB140 and RUT241.
   Device:     TRB140
   Kernel:     5.4.259
   Firmware:   TRB1_R_00.07.06.8
   Build:      ba806d4906
   Build date: 2024-03-21 14:37:27
root@TRB140:~# ps -w | grep ledman
 5340 root     22640 S<   /usr/bin/ledman -d
26576 root      1892 S    grep ledman
root@TRB140:~# /etc/init.d/ledman restart
26669 root      2024 S<   /usr/bin/ledman -d
26702 root      1892 S    grep ledman
Same here. Good catch.
Thank you for bringing this to our attention. The issue has been addressed in the new 00.07.06.10 firmware version. It is already accessible for use.
Marijus
00.07.06.10 solved it. Great!
