Make Modbus RTU data available on OPC UA Server
Good day,
I am using RUT906 routers to read data from sensors using Modbus RTU over RS485 and then pushing the data to various endpoints. Pushing the data to http and MQTT servers/brokers is easily configured and works without issue.
What I would like to know is how I would go about making data retrieved using the Modbus Serial Client available on the OPC UA Server module. I can install the OPC server package and connect to it, but I can see no way of configuring additional groups and values.
I have looked at using a script but neither the Modbus client not the OPC server modules expose much beyond a simple status call via the ubus command.
Any assistance would be greatly appreciated.
We are currently working on your issue and will get back to you as soon as we have an answer.
Thank you, your efforts are sincerely appreciated.
Hi, Marius,
Apologies for the long wait, as I was on a sick leave.
After double-checking, it seems that by default, this is not something that is achievable with our devices. What I can do for you, is register a suggestion for our R&D, so they could consider implementing this sometime in the future.
Thank you, Matas.
For the time being I will create my own OPC server on another system and just populate it with data from the MQTT broker.
Once again thank you for your assistance.
