We have a RUTC50 and are using the MAC Address Filter to whitelist devices connecting to the WiFi.
For some devices, it’s difficult or even impossible to determine the MAC address without first connecting them to the WiFi and inspecting the list of connected clients. My usual workflow for such cases is to temporarily disable the MAC Address Filter, connect the device, add its MAC address to the whitelist, and then re-enable the filter.
However, this approach is impractical with the current firmware (RUTC_R_00.07.11.1). Disabling the MAC Address Filter deletes all previously added addresses, so when I re-enable it, I have to manually re-enter the entire list of 30–40 MAC addresses—a tedious and time-consuming process.
Could this behavior be addressed in a future firmware update? It would also be great if the UI for managing MAC addresses could be improved. For example, having a dropdown is not a good solution. A more streamlined way to manage all addresses would make this feature much easier to use.
As a potential workaround, could you try increasing the DHCP server’s lease time or setting it to “Infinite” navigated to Network → DHCP → Edit? With this configuration, you should be able to see the previously added MAC addresses in the list without having to re-enter them manually.
Let us know if you have additional questions, or if further assistance is needed.
Do you mean that the previous devices should be listed in the MAC Filter under NETWORK > Wireless > SSID > Edit > MAC-Filter?
If so, the current implementation is quite inconvenient since the UI doesn’t allow assigning custom names to each MAC address. This makes it harder to keep track of which device belongs to whom.
It would be great if you could add a field for custom names when adding MAC addresses. For example, we could label entries with descriptions like “John’s black iPhone 13 Pro (test device)” for easier identification.
Anyhow, even with the suggested workaround, we’d still need to maintain a manually updated list outside the system to keep track of which devices should be allowed. This adds unnecessary complexity.
