Lvcan200 + fmc130
Good day,
I have some vehicles i’m fitting, Fiat, Ford, Isuzu and Toyota.
Ford and Fiat is working perfectly, but Isuzu and Toyota is not working at all.
Please share the wiring and manual for Toyota Hilux SRX please, we tried every possible program number on the program number sheet and still no response, we also tried the wires behind the cluster and at the OBD port.
We also followed the manual for the Isuzu Dmax and it also doesnt give anything, in the configurator, only program number and door status is green.
Good Day,
Thanks for writing to us.
Please note that we cannot provide the wiring diagram through this channel.
To obtain the wiring scheme, please contact us through the Helpdesk portal by creating a support ticket. If you do not have access to the Helpdesk, please get in touch with your direct reseller or your Teltonika Sales Manager. They will assist you in getting Helpdesk access or creating a support ticket on your behalf.
Once the ticket is created, we will be able to share the required wiring diagram and any other relevant technical documentation.
