Lua scrip to server
hi tetonika tim,
i try to read/write I/O pin and send to server.
this i try the code,
local PERIOD_SEC = 60 – samakan dengan Period di Collection
local HM_FILE = “/etc/hm_total.txt” – file penyimpan HM total
local equipment_id = “HT111” – ID genset / alat
local function read_hm()
local f = io.open(HM_FILE, “r”)
if not f then return 0 end
local v = f:read(“*n”)
f:close()
return v or 0
end
local function save_hm(v)
local f = io.open(HM_FILE, “w”)
if f then
f:write(string.format(“%.3f”, v))
f:close()
end
end
local status_genset = tonumber(data[“input1”]) or 0 – 1 = ON, 0 = OFF
local hm_total = read_hm()
if status_genset == 1 then
– jika genset ON selama PERIOD_SEC detik
hm_total = hm_total + (PERIOD_SEC / 3600.0)
save_hm(hm_total)
end
local trigger_genset = (status_genset == 1) and “1” or “0”
local t = os.date(“*t”) – waktu lokal router
local datetime = string.format(“%04d-%02d-%02d %02d:%02d:%02d”,
t.year, t.month, t.day, t.hour, t.min, t.sec)
local lat_val = tonumber(data[“latitude”] or 0) or 0
local lon_val = tonumber(data[“longitude”] or 0) or 0
local latitude = string.format(“%.6f”, lat_val)
local longitude = string.format(“%.6f”, lon_val)
local temp = “34.45”
local humy = “75.0”
local json = string.format(
“equipment_id”: “%s”,
“trigger_genset”: “%s”,
“status_genset”: “%d”,
“hm”: “%.3f”,
“latitude”: “%s”,
“longitude”: “%s”,
“temp”: “%s”,
“humy”: “%s”,
“datetime”: “%s”
equipment_id,
trigger_genset,
status_genset,
hm_total,
latitude,
longitude,
temp,
humy,
datetime
return json
but it not working,
what i mis.?
regard,
Hello @Gunawan_eko,
Good day! Could you help to provide more information on which you are trying to parse?
If you were parsing device records, it would follow the Codec Protocol. More information can be found on this link: Codec - Teltonika Telematics Wiki
Patrick
