I am using a RUT950 with LAN devices and Internet on WAN port with 100MBit/s. The throughput is max 45MBit/s while when connecting e.g. a laptop directly to the WAN device without RUT it is increasing to 97MBit/s, so almost 100. I use only a very few FW (default) rules and they are not complex, no NAT. The rules not used or not required I deleted - to be on the safe side.
Betwen RUT and end user devices is a simple 8 port switch.
I have enabled , and the throughput changed from 56 Mbit/s to 73 Mbit/s (with the RUT in between).
I ran another test without the RUT and it went further up to 90 Mbit/s. So there is still a significant difference, although the throughput is now much better.
Could you try closing the WebUI and disabling the unnecessary services on the device when running a speed test? RUT240 is quite processing power limited, thus it’s worth checking whether performing these actions will help.
I am testing the 950 only. I am reaching about 80MBit/s. So, because of a difference of roughly 15MBit/s I won’t continue investigationg. I am happy with 80MBit/s.
