Low LAN bandwidth RUT901
I have a router RUT901 that I recently purchased with firmware RUT9M_R_00.07.07.1. Since it has 3 LAN ports I am using it as an ethernet switch. I have seen in the specs that the bandwidth is 10/100 Mbps, but we only get 10 Mbps. Is it possible to use 100 Mbps by modifying the configuration?
Thanks in advance!
