I have tried to login to 192.168.1.1 and the response comes back with the following:
This site can’t be reached
192.168.1.1 took too long to respond.
My internet is working for any other site. Is there a problem with the site ?
thank youu
Mike
thank youu
Mike
Are you using a smartphone or some other device that’s connected to the internet via mobile data, but not connected to your routers WiFi? Try turning OFF mobile data.
Make sure you have a device connected to a LAN port on the router via an Ethernet cable, or you are connected to the router via it’s WiFi, and you’re not using VPN software.
Try rebooting the router and try again.
