Login to RUT360 failed
I just baught a RUT360 and start to setup. But the admin / admin01 was not accepted. I found somewhere that the password could also be the batch No, 32 in this case. But it did not work, I tried with 32, 0032, 3200, xx32 nothing works. Bad start…
I have also done a factory reset.
Found the password on the label, it does not work either…
Welcome to Teltonika Networks Crowd Support!
Since factory reset did not work, I would suggest you to proceed with bootloader which will reflash the current firmware. To do this, you can refer to this Wiki Article.
Let me know if this cleared your issue.
