Limit on VPN users per Souce public IP with VPN client
When using L2TP server with IPsec using IKEv2 is it possible to connect more than 2 remote users with same Remote IP address. Does %any fix this in Muliple??
Thank you for reaching out.
It is possible to connect more than two remote users with the same public IP address, as long as they are behind a NAT (Network Address Translation) device. However, if you’re considering a different approach, this would not be feasible. Could you kindly provide a topology or further details regarding your specific setup? This will help us to better understand your requirements and assist you more effectively.
Please feel free to reach out if you have any additional questions.
Kacper
