L2TP with non-standart port
Hello, I use RUT200 FW: RUT2M_R_00.07.04.5 and l2tp client working well. But i need connect to l2tp server with non-standart port (for example, 33099), is it possible? i tried x.x.x.x:33099 ,but server field not accept this notation.
Kindly refer to the link below regarding L2TP configuration examples that may help:
https://wiki.teltonika-networks.com/view/L2TP_configuration_examples
https://wiki.teltonika-networks.com/view/Setting_up_a_L2TP_over_IPsec_tunnel_between_Teltonika_Networks_and_Mikrotik_devices
In your situation, ALL ports are open by default in L2TP VPN; you can reach that L2TP server from its IP address without entering the port number; otherwise, some configuration on the L2TP server side is required to allow the L2TP Client to access on that specific port.
