L2TP tunnel and ping monitor
I recently installed a TRB140 to act as a backup WAN for an attached router. Unfortunately I don’t get a fixed IP address on this LTE link, the telco uses CGNAT - but I have an L2TP connection that does have static IP. This L2TP link, however, is much slower than the underlying LTE. I can buy a faster L2TP link, and may decide to do this in future depending on the stability. At present I will use the native CGNAT LTE connection as my default route.
I want to monitor the static IP address at the end of the L2TP link, to test how stable the LTE line is. If I set up a ping monitor, this gives me a great graph as long as the L2TP tunnel is set as the default route on the TRB140. As soon as I take the default route away, the ping monitor says things are down.
What do I need to do so that the default route remains the faster underlying LTE connection but the ping monitor works appropriately?
Two additional questions:
Is there a way to assign or pass through the L2TP static IP address to a router placed behind the TRB140, like setting up bridge mode for the LTE connection?
Will the TRB140 still answer on 192.168.2.1 when in bridge mode?
