Hello Everyone
i have Setup of the L@ network and i want to Bridge the Office network with remote site so can anyone help me to crate the VPN with Vlans ??
Hello Everyone
VXLAN should be the best fit for your use case. You can find more information, along with a configuration example, here: VXLAN Configuration Example - Teltonika Networks Wiki
If you encounter any issues while setting up VXLAN, I would need some additional details about your setup. Please provide a sketch of the network topology with IP addresses (excluding sensitive information such as public IPs), the VPN you intend to use, and what you currently have configured.
Hello Justinas,
Thanks for you time
I have remote site with two subnet 172.30.8.1 Vlan 10 & 172.30.9.1 Vlan 20.
same Vlan and same subnet at Office need to bridge trough VPN but once i add the VPN to the VPN tunner can bridge with One VLAN at a time.
Could you clarify some additional details about your setup? Please provide a sketch of the network topology with IP addresses (excluding sensitive information such as public IPs), the VPN you intend to use, and what you currently have configured.
Additionally, have you tried setting up the VXLAN following the configuration example?
