Keypad + FMC130 immobiliser: wiring and configuration guide (from the manufacturer)
Full disclosure — we make these keypads at Tracking Hardware UK, so we know the wiring well. Following on from our FMB130 keypad guide, this one covers the setup we get asked about most: a PIN keypad on the FMC130’s 1-Wire interface driving the Immobilizer scenario, so the engine will only start after a valid PIN.
What you’ll need
  • FMC130 on reasonably recent firmware, plus the Teltonika Configurator
  • A 1-Wire PIN keypad that emulates a Dallas iButton (ours is the EC-19521, but the steps are identical for any iButton-emulating keypad)
  • A standard 5-pin automotive changeover relay (coil voltage to match the vehicle) and an inline fuse
Wiring — keypad
Pin numbers are from the FMC130 pinout on the Teltonika wiki — double-check against your harness before crimping anything.
  • Keypad yellow → vehicle power, 8–36 V (12 V and 24 V both fine)
  • Keypad brown → ground, on the same ground point as the FMC130’s GND (pin 7). A shared ground is not optional on 1-Wire
  • Keypad white → FMC130 1-Wire DATA (pin 11). It is easy to land this on a regular DIN by mistake — count twice
  • Do not power the keypad from pin 10 (1WIRE POWER). That pin is a +3.8 V output meant for iButton readers; the keypad takes vehicle power on its yellow wire instead
Wiring — immobiliser relay
DOUT1 (pin 8) is an open-collector output rated 0.5 A — it switches to ground rather than sourcing power, so it can’t interrupt a starter circuit on its own. Hence the relay:
  • Relay terminal 85 → FMC130 DOUT1 (pin 8)
  • Relay terminal 86 → ignition-switched +12 V, fused
  • Run the starter solenoid feed through terminals 30 and 87a (the normally closed pair). While the scenario holds DOUT1 active the relay is energised and the circuit is broken; once a valid PIN is entered DOUT1 releases and the circuit closes again
For safety, always interrupt the starter motor circuit rather than fuel or ignition — that way nothing can cut power while the vehicle is moving.
Configurator settings
  • System: confirm your ignition source. DIN1 (pin 5) is the usual choice
  • Features → Immobilizer: enable the scenario, set the controlled output to DOUT1, and set the authorization ID list checking to 1-Wire (on current firmware at least one checking method must be selected)
  • Ignition Off Timeout (default 25 s) sets how long authorisation survives after ignition-off before the driver must re-enter a PIN. One side effect worth knowing: if it’s longer than your sleep timeout, the device may never sleep
  • iButton List: this is your whitelist. To capture each keypad ID, wire everything up, have the driver enter their PIN and press *, then read the ID from Status → I/O info in the Configurator and add it to the list. Important: an empty list means any ID authorises, so the immobiliser isn’t protecting anything until this is filled in
  • I/O: set the iButton element priority to Low or higher so driver IDs reach your platform in records (note these records are only generated while ignition is on)
Testing
  1. Ignition on, no PIN → the vehicle should refuse to crank
  2. Enter a whitelisted PIN and press * → the keypad transmits, DOUT1 releases, and the vehicle cranks normally
  3. Ignition off, wait past the Ignition Off Timeout, ignition on again → blocked until a fresh PIN
Common problems & fixes
  • If a setting here doesn’t match what you see, your firmware may differ — the current field names are always in the Configurator itself and on the wiki: FMC130 Features settings. For the full pinout, search “FMC130 First Start” on the same wiki
Happy to answer follow-ups here — we support these units directly.
Good Day,
The Keypad integration over 1-Wire will be a custom development project (CDP). Kindly contact your sales manager so that they can assist you with creating a Partner Portal ticket.
Thanks, and best regards,
Imran S.
