Could you please confirm if your TRB246 is running the latest 7.17.3 firmware? If not, please download it from this page, update the device, and check if the issue persists.
Thanks Marija. It looks bettter after upgrade. vpnoff worked immediately. vpnon required multiple attempts. I will retry testing and report if necessary
I did run again another test: it looks that it does not consider the new vpnon message for around 1-2 minute. then it worked. Maybe because the TRB is busy still managing the vpnoff request. but nothing is in the event log. hence my initial suspicion on the modem
If I understand correctly, both vpnoff and vpnon commands work, but for vpnon you need to wait a little while for the VPN to actually be enabled, right?
If that’s the case, this is normal—sometimes it just takes a bit of time to enable the VPN.
The issue when reactivating the VPN is not the vpnon command per ser. It is rather that the SMS is sent, well received (according to the mobile operator) but not processed by the TRB (it is not visible in the event log).
