Issue with LAN-to-LAN on RUT200
I am using RUT200 devices to create a LAN-to-LAN connection to the Vigor2925 (the main modem). I use these RUT200 devices to monitor the parameters of PLCs installed in different countries.
The issue I am facing is that the RUT200 devices installed in Vietnam (where the Vigor2925 is located) are working perfectly. However, the RUT200 devices in other countries cannot connect to this Vigor device.
Could you please advise me on what to check and how to resolve this issue?
Thanks in advance!
Could you please provide your RUT200 product code?
Hello Marija,
I’m using RUT200: E24-10R-06 (which shows on nameplate).
I’m not sure if that’s the production code, so please tell me if it’s wrong.
Many thanks!
Here, you can see all product codes (Hardware version) for the RUT200 device:
Please let me know which product code your device has.
Thank you for your information. Upon checking, my RUT200 has the following specifications as per the attached image:
  1. Product code: RUT20001XXXX
  2. Hardware revision: 0003
    Please review and assist me further.
Apologies for the late reply.
Could you please clarify what you mean by “in other countries cannot connect”? Which specific countries are you referring to?
Additionally, please ensure your device is running the latest firmware version 7.13.4. You can download it from the following link: RUT200 Firmware Downloads - Teltonika Networks Wiki.
