Issue Creating Juggler Action via API for RUT956
Dear Support Team,
I’m encountering a problem while attempting to create a juggler action through the API for the RUT956 router (Firmware Version 7.6.0; API Version 1). My goal is to configure certain parameters via the API, but I’ve hit a snag.
Endpoint Used:
/io/juggler/operations/config
Request Body:
“post”: “1”,
“ui_params”: “1”,
“text”: “{\n\t"serialNumber": "%sn",\n\t"adc0": "%g1",\n\t"din1": "%g2",\n\t"din2": "%g3",\n\t"dout1": "%g4",\n\t"dout2": "%g5",\n\t"iio": "%g6",\n\t"relay0": "%g7"\n}”,
“type”: “http”,
“ui_name”: “testaction”,
“verify”: “1”
Error received:
“success”: false,
“errors”: [
“source”: “ui_name”,
“code”: 103,
“error”: “Option is required when creating a configuration.”,
“section”: “.anonymous”
According to the documentation, the ui_name field is mandatory and I’ve provided it under the attribute “ui_name”: “testaction”, assuming this is the correct way to name the action. However, the error suggests that a required option is missing.
Could you please clarify if my understanding of the ui_name (as mapped to $uci_name) parameter is correct? Or if there’s another issue with my request that’s causing this error? Your guidance on how to correctly create a juggler action would be greatly appreciated.
Thank you for your assistance.
Alejandro Haag
ah@speam.io
+491797217225
Are you including the ‘data’ key in the JSON body?
Please, try the following:
    "data": {
    "post": "1",
    "ui_params": "1",
    "text": "{\n\t'serialNumber': '%sn',\n\t'adc0': '%g1',\n\t'din1': '%g2',\n\t'din2': '%g3',\n\t'dout1': '%g4',\n\t'dout2': '%g5',\n\t'iio': '%g6',\n\t'relay0': '%g7'\n}",
    "type": "http",
    "ui_name": "testaction",
    "verify": "1",
    "url":"example.com"
