I need to troubleshoot a TSW202 remotely and don’t have access to one in the lab at the moment.
After a factory reset, in addition to the default static IP, is DHCP enabled? i.e. will the switch obtain a DHCP lease and if so, can that interface be used for management access?
Yes, by default the TSW202 has a DHCP client interface enabled and will obtain a DHCP lease from the network’s DHCP server. You can access and manage the switch via the IP address assigned to that interface.
Feel free to reach out if you have any further questions.
