IPsec tunnel up - cannot ping from lan but from cli is pinging
I’m little confused with rutx behevior, when IPsec tunnel is up.
Using RUTX11 fw:RUTX_R_00.07.06.1
against cisco
ipsec connection is done ok
Security Associations (1 up, 0 connecting):
rep1-rep1_c[1]: ESTABLISHED 14 minutes ago, 62.141.xx.xx[62.141.xx.xx…81.91.xx.xx[81.91.xx.xx]
rep1-rep1_c{1}: INSTALLED, TUNNEL, reqid 1, ESP SPIs: c6856a81_i 73541203_o
rep1-rep1_c{1}: 172.18.24.0/24 === 172.18.0.0/19
rep1-rep1_c_1{2}: INSTALLED, TUNNEL, reqid 2, ESP SPIs: c5eef07f_i 0ba1c5a0_o
rep1-rep1_c_1{2}: 172.18.24.0/24 === 172.23.0.0/16
now I can ping hosts in 172.23.0.0/16, 172.18.0.0/19 networks but only from the router CLI
my LAN ip is 172.18.24.1/24 and after tunel up, my PC lost connection to router at all
(no DHCP, no ping)
When the tunnel is down, PC to router connection is working again.
I missing some policy based routing, can you help me?
thanks
I believe the issue in this case is the overlap of LAN and networks behind IPsec, since 172.18.0.0/19 covers hosts from 172.18.0.1 to 172.18.31.254. It is surprising that you’re not able to reach the RUTX11, as it has a more specific route to it’s LAN, but either way, I’d suggest removing 172.18.0.0/19 from the remote networks in the IPsec configuration (or changing your LAN subnet) and checking if the issue is still present.
thank you.
Overlaping subnets is the problem.
