I updated my RUTX50 to latest firmware 7.12 and now i have problem with the IPsec VPN tunnel. First i had to enable “Force crypto proposal” to get it connected at all but when I restart the unit it dosen´t reconnect automatic. I need to disable the VPN connection in RUTX50 unit and enable it again. Then i connect again. I have tried to enable DPD but it doesen´t help. (The VPN IPsec tunnel connects to a gateway on a Zyxel USG310 router).
I have sent you a form to fill out. Once completed, we will contact you privately regarding this issue. Please use ticket ID “11905” when submitting the form.
