RUT9M_R_00.07.17.1
ipsec works, but does not show that it works
it does not collect logs
Could you please confirm if the same issue persists on the latest 7.17.3 firmware version?
Yes, it still doesn’t show.
Hello!
This issue seems to be present for someone else as well, as can be seen here: RUTM10 IPsec wrong status
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 15434.
With version 7.17.4 the issue is gone. Status is shown.
