Hello
We are running a small PoC of a couple of routers for a IPSeC based on certificate authentication.
After the upgrade to RUTM_R_00.07.25.3 100% of our RUTM30 couldn’t connect to the IPSec VPN, with the error "no private key found for ‘CERTIFICATE CN’
After removing and readding the certificate privatekey to the TPM module, no change.
After removing and readding the certificate without moving it to the TPM module it started working.
When looking at swanctl no TPM plugins are loaded, but unfortunately i do not have an old router to verify if a tpm module was loaded on the earlier version.
root@RUTM30:~# swanctl --stats
uptime: 3 minutes, since Nov 02 14:50:15 2026
worker threads: 16 total, 11 idle, working: 4/0/1/0
job queues: 0/0/0/0
jobs scheduled: 2
IKE_SAs: 0 total, 0 half-open
loaded plugins: charon mgf1 random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pgp dnskey sshkey pem openssl pkcs8 xcbc kdf ml curl sqlite attr kernel-netlink resolve socket-default connmark vici updown eap-identity eap-mschapv2 xauth-generic
root@RUTM30:~#
Any advise, as we would prefer the private key to be stored on the TPM module, and not just in the flash of the device ![]()
Best regards
Jonatan
