Hi All,
I want to know that can I use UL202 Ultrasonic Fuel Sensor with RUT955 gateway or other similar gateway?
Hi All,
RutOS does not have capability to interpret the information received via the RS232/485 ports, and the best solution I could suggest here would be to use Serial over IP functionality and process the RS signals remotely.
Serial over IP works by encapsulating the serial communication within TCP/IP frames, thus allowing the serial connections to be transferred over the internet.
RUT955 can only really be used with analog sensors (0-24 V), digital boolean sensors (1 or 0), or 4-20mA sensors.
However, we do provide a software development kit available, so if developing software is something that you’re familiar with, instructions and downloads can be found here:
https://wiki.teltonika-networks.com/view/Software_Development_Kit
Thank you Daumantas for your response.
Can you please provide complete specification with min max measuring range and picture of Analog Fuel Sensor and UL202 Ultrasonic Fuel Sensor.
We do not sell such devices, so I cannot provide any concrete information about any analog sensors. As for the mentioned device, our colleagues at Teltonika Telematics have a Wiki article about it here:
https://wiki.teltonika-gps.com/view/UL202_Ultrasonic_Fuel_Sensor
