Install Speedify to Teltonika RUTX12
As Bondix is way too expencive for private users, can you please get your heads into how to install Speedify for OpenWRT onto your RUTX Router range ?
Thx.
Currently, there is no available 3rd-party package for Speedify in the OpenWRT repository. To explore all available packages in OpenWRT repositories, you can use the following commands through CLI/SSH:
opkg -e /etc/opkg/openwrt/distfeeds.conf list
Hi…
They have instructions and support to install it on raspberry4.
Getting Started with Speedify on OpenWrt or GL.iNet Devices - Speedify Knowledge Base (raspberry 4 + openwrt)
Maybe it will not be a clean solution, but you can build a solution to use Speedfity with your RUTX12 + Raspberry 4.
About Bondix… I was a Bondix customer… But I give up… because they don’t update the software and don’t have hub and spoke vpn solution for three sites and more.
I was already in touch with Speedify and they investigated the case. It turned out the following:
"Hi Marco,
Thank you for your response!
It seems that the operating system on the router does not have the option of installing the Luci UI. I’m afraid you won’t be able to have it on your router.
In your case, it seems that you can use Speedify on your router through the CLI: Getting Started with Speedify on OpenWrt or GL.iNet Devices - Speedify Knowledge Base
Regards,"
This is more or less the same article linked as it was by Marcelo. So maybe it can run without UI.
This is what comes out, when you try to install their official packages:
root@RUTX12:~# wget -qO- https://get.spee/
[This may take some time on some systems]
Speedify must restart networking on thi
e installed correctly.
  • If you are connected to your router o
    may lose your connection and join anothe
    k.
    Please ensure that you are connected
    's wifi network in a few moments.
    your connection may be interrupted momen
    Installing speedify with opkg…
    Updating opkg…
    Downloading https://opkg.teltonika-networ/
    3c5f8c22111eedc6da5d343058fdb43d26946a79c
    6c34/Packages.gz
    Updated list of available packages in /va
    tlt_packages
    6c34/Packages.sig
    Signature check passed.
    Installing speedify_arm_cortex-a7_neon-vf
    -app-speedify_all.ipk for architecture ar
    eon-vfpv4…
    Fetched https://downloads.speedify.com/sp
    rtex-a7_neon-vfpv4.ipk
    Fetched https://downloads.speedify.com/lu
    fy_all.ipk
    Installing speedify (15.1.1-12217) to roo
    Installing libstdcpp6 (8.4.0-3) to root…
    6c34/libstdcpp6_8.4.0-3_arm_cortex-a7_neo
    Unknown package ‘luci-app-speedify’.
    Configuring libstdcpp6.
    Configuring speedify.
    Installing network and firewall rules for
    No firewall zone for Speedify found, crea
    cfg19dc81
    cfg1aad58
    cfg1bad58
    cfg1a0f15
    Restarting the network and firewall after
    Successfully created Speedify’s network,
    system service
    Package installation encountered an error
    eviously installed packages.
    Removing libstdcpp6
    Refusing to remove essential package libs
    Removing an essential package may
    nusable system, but if
    you enjoy that kind of pain, you
    g to proceed against
    its will with the option: --force
    ssential-packages
    opkg_remove_pkg failed
    Removing speedify
    Removing package speedify from root…
    Stopping and disabling Speedify’s system
    Removing Speedify’s network and firewall
    find: /tmp/custom_package: No such file o
    /sbin/opkg-cleanup: line 36: can’t open :
    tar: invalid magic
    tar: short read
    tar: invalid magic
    tar: short read
    Collected errors:
  • pkg_hash_check_unresolved: cannot find
    uci-nginx for luci-app-speedify
  • pkg_hash_fetch_best_installation_candi
    s for luci-app-speedify found, but incomp
    he architectures configured
    Calling opkg-cleanup for libstdcpp6Callin
    p for speedifySpeedify has been installed
    Here are some resources you might find us
