Inpu/Output Juggler condition Time script help
Hello!
Found this topic https://community.teltonika.lt/t/inpu-output-juggler-condition-time/5372
Marijus solved it by explaining some sripting.
Tried to follow the instructions but getting stuck on the escape after entering the script.
Press “Esc” and then type :wq to save and exit.
Putty returns that “q” is not implemented.
Also tried via the terminal in the RMS page… same result.
i have a TCR-100 that i would like to have sending SMS texts every 2 hours to the same nr,
Maybe this stuff is too complicated for me :confused:
You can try typing :x instead of :wq. This command will save the file and exit if any changes were made. If no changes were made, it will simply exit.
Hope this helps!
