I want to buy a fleet of scooters that have teltonika tft100 as gps
Hello, i want to buy a fleet of scooters that have teltonika tft100 as gps, how i can make sure that old ovner wont be possibile to recive any more data after we buy them ? we want to transfer then on our own server. and as i know there are fota web that the actual owner can change and recive data from the iot.
Hi @Tolds1939
Good day, if you change the server details then the device will not send records to the old server configuration.
Regarding FOTAWEB you can ask your distributor to give you an access with an NOC and transfer it to your account.
Please check with your sales manager or contact directly your reseller regarding the FOTAWEB access.
FOTAWEB can be use to update firmware, configuration, logs, check the status of the device if it is online etc.
If you don’t want to use the FOTAWEB you can also disable it from the configuration.
Best Regards
Maynard C
