Hi I have been able to successfully connect to my remote devices on the RUT240.
but it seems erratic it works 1 day then sub-sequentially fails on next day. I haven’t changed any settings
but I can’t even get a ping response from the devices. This has repeatably happened and I now suspect the VPN Hub maybe unstable or that there maybe something missed in my configuration?
Hi…
Are you using WiFi to connect all devices?
Can you force the WiFi to stay at same channel?
Sample… keep using channel one… no allow it to change fro channel one to another channel.
It solved. sandtrix
