How to setup Omron CJ2M PLC by use RTU200?
Maybe share more information, what is your use case? Do you want to remotely connect to the plc, do you want to create a remote connection with a protocol? You want to interact the PLC with the RUT ?
As @troboganz has inquired, could you please provide more information on what you’re trying to achieve? Are you using any other platforms, such as RMS for your setup?
