How to setup a basic NAT on RUT300
Hallo, I want to use the RUT300 as an basic NAT device. For this I would like to use the web-interface to setup the device. Four WAN ip’s should be translated to 4 LAN ip’s and vice versa.
Or is it only possible with Network → Firewall → Custom rules??
The WAN interface is in NAT mode by default and will function as you described. If you have a different idea in mind, please provide more details on what you’re trying to achieve, and we can work together to find a solution.
Marijus
