How to set up minimum charging current
Hi I have Teltonika EVC2 charger with CT clamps and a Renault Zoe which requires 10A charging. The problem is that when I turn on something in the home, the charger tries to lower charging current below 10A and the car throws I fault charging current too low. So is it possible to set up my charger to pause charging when there is no spare current? Teltonica app doesn’t have an option to pose charging when charging current drops below the set point.
So any suggestion?
