How to send emails from S7-1200 PLC to a group of email addresses using Teltonika RUT241?
How to send SMS from S7-1200 PLC to multiple numbers at the same time via rut241? Thanks in advance.
[Sending emails over secure email connections with S7-1500 and S7-1200]
Teltonika support does not work, I will offer my option. In TIA side- TMAIL_C. Using the “TMAIL_C” instruction, you can send an email via the Ethernet port of an S7-1500 CPU of V2.0 and higher or S7-1200 CPU of V4.1 and higher, a communications module (CM) or communications processor (CP). More about it you find there: (https://plctab.com/wp-content/uploads/2021/07/46817803_EMail_with_SimaticS7_en.pdf) For sending receiving SMS messages use TC_SEND and TC_RECV. More about it you find there:(https://cache.industry.siemens.com/dl/files/808/67196808/att_108115/v3/net_s7-1200_isoontcp_en.pdf)
In RUT241 side SMS configuration: Navigate to Services → Mobile utilities → SMS Gateway → POST/GET. Enable the Mobile Post/Get Settings. Create username and password. Then go to System → Administration → Recipients → Phone groups add new phone numbers group. I also added the RUT241 sim card number to group (that my “work around” for SMS Forwarding To Email). Try whether it works. Send mobile message to a group http://192.168.1.1/cgi-bin/sms_send?username=user1&password=user_pass&group=group_name&text=testmessage
I don’t use “Tmail_c” in TIA. I chose to use “SMS Forwarding To Email”. Go to System → Administration → Recipients → Email users. Add (sender) Email account. Navigate to Services → Mobile utilities → SMS Gateway → SMS forwarding → SMS Forwarding To Email Configuration. Example: SMS Forwarding Configuration Example - Teltonika Networks Wiki That all.
