Hi. What’s the fastest way of manually witching between wired WAN and Mobile, hopefully with a click of a button? I’m unable to update because the unit is at remote location with very slow internet, so current firmware is RUT2XX_R_00.01.14.5. In it: Network - WAN, selecting WAN at the left and hitting SAVE takes fairly long time to apply the change but I want this switch to happen very fast.
Unfortunately, with legacy firmware versions, the process may take longer. To speed things up, consider updating your device to a newer firmware version.
Additionally, you can try using SMS utilities to turn the mobile interface on or off. For example, to enable the mobile interface, send an SMS with the text <router_password mobileon> to your router’s SIM card phone number. More details can be found here: RUT240 Mobile Utilities.
You can also access the router via the CLI (Command Line Interface guide) and modify the network configuration there, although it may not be faster than using the WebUI.
Please let me know if you need any further assistance or have more questions.
