How to enable/disable wan I/F via SSH on RUT950 V6
Hi
can you please let me know which command I have to issue to RUT950 v6.x router to enable/disable WAN port eth1?
Need to troubleshoot some problems I’m facing and this will help a lot
Matteo
The easiest way will be to use the commands:
ifconfig eth1 down #disable the interface
ifconfig eth1 up #enable the interface
These commands will only apply until the device is rebooted. If you’d like them to apply even after the reboot, you can use
uci set network.wan.enable='0' #disable the interface
uci commit network #commit the changes
/etc/init.d/network restart #restart the network service
And these for enabling the interface:
uci set network.wan.enable='1' #enable the interface
Hope this helps!
Hello Daumantas,
thanks
Is there commands like ifconfig ethx to check the interface status in real time?
Matteo
The ifconfig eth1 command could be used to check if the WAN interface has received and IP address from the upstream device. For example, here is the output when no DHCP lease is aquired:
And here is an example with the interface running:
Just to clarify, you are not able to update to the latest firmware due to hardware limitations?
Yes I can’t update the router otherwise with Version 7 GUI I could check it more simply
Or do you have different commands with latest firmware?
Thanks for now
Matteo
With the latest firmware, I’d suggest to use ubus commands for checking the status, and enabling/disabling the interface, but that would simply be more convenient for you to script, the end result is the same.
Best regrads,
do you have a list of ubus command or a link to provide?
Matteo
They would be:
ubus call network.interface.wan down #disable the WAN interface
ubus call network.interface.wan up #enable the WAN interface
And to check the status:
ubus call network.interface.wan status
jsonfilter can be used to parse only the relevant part:
ubus call network.interface.wan status | jsonfilter -e '@.up'
This will return true if the interface is up, and false if the interface is down.
