How to configure routing?
I have a RUT240, Firmware RUT2_R_00.07.06.17. I successfully configured a IPec-VPN-connection via mobile network to my Gateway (Lancom) via public IPv4-Adress.
Private Gateway-IP is 10.2.100.1, it has many VPN-Client-Routers (Lancom) with 10.2.1.1/24 to 10.2.90.1/24.
The RUT240 has 10.2.85.1. Routing at the gateway is working for every client network.
But I can´t configure a working routing at the RUT240.
Both physical ETH-Ports are bridged as LAN with 10.2.85.0/24 and DHCP-Server, IPv4 only, Clients get a IP as configured. Clients can ping the gateway 10.2.100.1, but no other adress. Traceroute shows only the RUT as first hop, no other entry.
I configured static routing table with Interface “mob1s1a1” and target 10.0.0.0, netmask 255.0.0.0 and gateway 10.2.100.1 as Unicast, without success. I tried adding a WAN-Interface with 10.2.85.0/24 and using this as Interface, also without success.
Even target 0.0.0.0 with netmask 0.0.0.0 didn’t work.
Is there a possibility to selct the VPN as interface? Do I have to configure local/remote IP-adresses inside the VPN-configuration?
Clients need connection to 10.0.0.0/8-networks and 192.168.0.0/16, all available vie the gateway 10.2.100.1, all traffic should be route to the VPN.
My other VPN-Clients are LANCOM-routers, there I use n:m-mapping, so all local clients are in the local network 10.2.0.0/24 and can by reached from central network with a correspondending IP from the VPN-tunnel.
Thanks in advance for help.
Sven
Apologies for the delayed response. Could you please confirm if you still require assistance with your issue?
yes, the problem is unsolved an help would still be very appreciated.
Best regards
Unfortunately, when configuring routes, it is not possible to select IPsec as an interface for routing.
Instead of creating static routes, I recommend navigating to the IPsec tunnel settings and configuring the following:
  • Local subnet: 10.2.85.0 (RUT240 LAN)
  • Remote subnets: 10.0.0.0/8 and 192.168.0.0/16
Please let me know if this helps or if you need further assistance.
thank you for this. Unfortunately it didn’t work.
When I delete all static routes and add 192.168.0.0/16 as remote network I still can’t reach or even ping devices there (also not the other way around). When I add 10.0.0.0/8 as remote network I even cant’t access the router webinterface from a local computer at the LAN-port.
I tried to add 10.2.48.0/24 as remote network but can’t ping devices there.
Monitoring the VPN-gateway I don’t see any packets from the router, so it’s not a routing problem at the VPN-gateway.
Best regards
