How to change the SMS login and password on the FMC650 and FMC125?
Is it possible to change the SMS login and password through a remote command on FMC650 and FMC125 devices?
Currently, they have the default login and password, and I need to configure new ones. However, when I send<space><space>setparam 3003:admin
the device responds with: new value 3003:;
Hi, you should be able to change the login and password with the same command. Confirm if the spaces are not being removed from the command as iOS usually removes the spaces.
That’s correct, it sends the spaces correctly and they are not removed. I’ve tried different ways, and when the spaces are not sent for the login and password, it simply does not respond. When the spaces are sent, it responds as if it had been configured, but empty.
