CPU Mediatek, Dual-core, 1.3 GHz, ARM Cortex A53 RAM* 512MB DDR3 RAM** 1GB, DDR4 FLASH storage* 16MB serial NOR flash, 512MB serial NAND flash FLASH storage** 16MB serial NOR flash, 8GB eMMC *Feature availability varies by order code (RUTC50 *0****) **Feature availability varies by order code (RUTC50 *1****)
Both the RUTX50 and RUTM08 are well-suited for 1 Gbit connections and are designed to deliver high throughput. However, performance can vary depending on your specific use case, especially if you plan to implement resource intensive features such as extensive VPN configurations or complex firewall rules.
I have contacted our RnD team regarding specific test cases. Once I get an answer from them, I will get back to you.
I was thinking of normal every day use. Maybe downloading and uploading from servers/websites without VPN as it can be power hungry. Maybe up to 20 clients on the network type of scenario.
It would be quite good to achieve high download/upload speeds as the rutm08 is the cheaper option if i compare to a fritzbox for instance. The fritzbox would have wifi, but that is another discussion. A tap200 could be placed closeby.
There is a difference in specs, one has two cores vs 4 cores(rutm08 & rutx50). Also different clock speeds, however very low clock speeds compared to other product brands.
Which one would perform better for download/upload , 2 or 4 core processor?
