I would like to know if teltonika’s 4g routers are compatible with these eSIM ? :
I can’t find any information about this “bearer independent protocol (BIP)”
Hi, @Al44! Hope you’re doing good. I sincerely apologize for the delay in responding to your post.
Yes, the Teltonika RUT241 eSIM is compatible with BIP, although it needs to be enabled via AT-Commands.
You will need to make sure that QSTK is set to 0:
# gsmctl -A AT+QSTK=0
The second AT-command is for enabling BIP. Please pay attention to the apostrophes, as they are essential for the cellular module to interpret the command correctly:
# gsmctl -A 'AT+QCFG="bip/auth",1'
Further information can be found at the following link:
For general information, please refer to this link:
Best Regards.
