Get ICCD from RUT955?
Is there a way to remotely get ICCD of RUT955 SIM?
Thanks.
You can get this information by sending the AT+CCID command. The easiest way to do this is through your router’s web interface. Go to System > Maintenance > Troubleshoot. Scroll to the bottom of the page to find the Modem Debug section. Enter the command AT+CCID and press send. You will receive a response with your ICCID code.
