Generator config
I use many routers RUT241 and I want to make config generator which prepare settings with ip, dhcp and openvpn. Then I want upload to route.
Is it exist some solution in Teltonika routers?
Another solution is make backup, unzip backup, make change in files, zip all and upload to router. Will this work?
Thank you
Dariusz
You can generate a backup file from one RUT241 device and upload it to others. Detailed instructions can be found on our wiki page: RUT241 Maintenance - Create Backup.
Additionally, you can use the RMS platform to configure multiple devices simultaneously. More information is available here: How to Configure Devices from RMS.
Let me know if you have any further questions.
