FW problem rut240
I have a problem, I have reloaded the firmware from RUT2_R_00.07.04.2 to the latest in two rut240 modems. In both modems I have SIM cards on which I set a monthly data limit ( 3GB ),
after reloading FW to the latest one, I received an SMS notification that the data limit has been exceeded and I lost remote connection with the modems. Is there any command I can send through SM to deactivate the set monthly data limit ?
Regards.
Thanks for reaching out!
You can reset mobile data usage via SMS.
Please refer here for detailed description.
Caner
With the Mobile Data usage reset action there is no default command to send. Do you know what such a command should look like?
This rule is not added by default. You should create a rule and choose a SMS text to trigger the rule.
It can be done from the WebUI, from the Services > Mobile Utilities > SMS Utilities .
After rule is created you should click Save&Apply.
And then you can change authorization of the rule if you want.
Caner
