Function accelerometer fmb125
Good afternoon. Tell me how to send only one SMS only when the function changes to value 1? Now 2 SMS are sent with the value 1 and then an SMS with the value 0. This happened after updating to the latest firmware version.
FMB125, 03.27.13.
Good day, Thank you for contacting Teltonika Telematics!
Please let me know which feature you will be needing the SMS alert when value became 1?
Ashutosh S.
Good afternoon. yes, that’s right, I need SMS only by value 1
You can set event in the I/O option from the device configuration. Please see the link below.
Ashutosh S.
Good afternoon. Thank you. tell me which parameter I need to select in the input/output menu? I saw the “towing” function setting only in the accelerometer menu.
Please provide which parameter you want to enable or you want to get SMS from that parameter.
Ashutosh S.
Good afternoon. I need to configure sending SMS when the accelerometer is triggered.
Good afternoon. I’m really looking forward to your answer. Thank you
Please check the settings below
If you want to receive only the records when the movement is detected change the high value to 1 and the low value to 1 and change the operand to on entrance.
Regards
Maynard C.
This topic was automatically closed after 32 hours. New replies are no longer allowed.
