Fuel level values. why limited to 32767?
regarding FMB125 and its fuel level values
https://wiki.teltonika-gps.com/view/FMB125_Teltonika_Data_Sending_Parameters_ID
why parameter 270 BLE Fuel Level #1 is unsigned and range from 0 to 65535
But parameter 201 LLS 1 Fuel Level is signed and ranged only to 32767 ? why do you need negative values -4 … -1 ?
to my understanding they should be the same 0-65535
in addition how do you handle FLS that report values higher then 32767 or 65535?
thanks
rafi
Hi
Good day, if you have any issues/discrepancies or encounter any problems with our wiki page kindly contact your sales manager or create an HD to fix the issue.
Best Regards
Maynard C
thanks, but it is not a discrepancy in wiki page, it is a clarity question about the range values of the 2 params i mentioned. i wonder why there is a difference? and how Teltonika supports FLS that report higher values then 65535?
we work with many sensors that report values much higher than 65535
