: FTC921 – DIN1 stopped working after updating from 1.5.1 to 3.7.3 via TCT (Skipped MCU update)
I updated two FTC921 devices from factory firmware 1.5.1 directly to 3.7.3 using TCT. After the update, DIN 1 (Ignition) completely stopped working on both units.
Hardware & wiring ruled out:
A third unit running the factory 1.5.1 firmware works immediately and reports DI1:1 on the exact same harness and vehicle. Vehicle wiring and ignition signals are 100% fine.
The issue is clearly that the intermediate MCU update for the AG3335AT chip (FTC921.AG3335AT.Ver.2.1.4.wmi.e.xim) was skipped, and now TCT blocks downgrades from 3.7.3.
Situation:
  • I don’t have FOTAWEB access yet (already requested through support/distributor).
  • I cannot downgrade via TCT.
  • DIN 1 is strictly required for this project.
Request:
Can someone provide the recovery package or instructions to reflash the AG3335AT MCU / recover DIN 1 locally via TCT?
Good day,
The issue where DIN1 stops working after updating from firmware version 1.5.1 to 3.7.3 is a known behavior on the Gen 5 (FT/AT) platform. This occurs because the Device Tree Blob (DTB) version is not automatically updated during a standard firmware migration to the 3.7.x branch, causing the device to stop recognizing or sending the din.1 parameter.
Updating from firmware 1.x.x to 3.7.x will required our Technical Support to assist with the update.
Please raise this issue via Helpdesk and provide the device information through it. Our technical support team will assist you accordingly.
Muaz Z.
