FTC887 – Ignition remains ON despite voltage below threshold
FTC887, firmware 3.0.90.
Configuration:
  • Ignition sources: Power Voltage + Accelerometer
  • Smart Ignition: Disabled
  • Low Voltage threshold: 13,200 mV
  • Movement Stop Delay: 60 seconds
Actual AVL data:
  • External Voltage (AVL 800): 12,984 mV
  • Movement: 0 (vehicle stationary for hours)
  • Ignition: 1
Expected Ignition = 0, but the device continuously reports 1.
What could cause Ignition to remain ON under these conditions?
Good day,
Based on the configuration and data provided for the FTC887 (firmware 3.0.90), the ignition remaining ON despite the voltage being below the threshold and the vehicle being stationary is a known behavior related to the Ignition Source logic and Smart Ignition settings on the Gen 5 platform.
Firmware 3.0.90 is an early release for the FTC series. Significant improvements to ignition detection and “stuck” status handling were introduced in the 3.7.x branch.
Kindly please reach out to us via Helpdesk so that out technical support can assist you with the firmware update as the firmware update needs to be done using the Bundle update (.FTMFC) via TCT or FOTA WEB to ensure the Device Tree Blob (DTB) is updated, otherwise, I/O parameters may stop working entirely.
Muaz Z.
