i need the can protocol for FTC305 anybody can help?
Greetings!
Could you please elaborate on your question?
The FTC305 is an e-mobility tracker that supports CAN data reading. The device allows users to configure manual or automatic baud rate detection and supports configuration of up to 70 manual CAN IDs.
The device itself does not come with a predefined CAN protocol. Instead, the required CAN protocol can be integrated by configuring the CAN parameters such as CAN IDs, baud rate, CAN type, data mask, and related settings (these details can be fetched from the CAN communication protocol of the device to be integrated, eg: A BMS)
Please refer to the link below for a better understanding of the CAN configuration process,
The following link provides details on the Data sending parameter ids (AVL IDs) for the Manual CAN I/O elements,
Thanks,
BR
