Forbidden response on RMS API /DEVICES/CREDIT put
I have the same problem as reported in the old forum at FORBIDDEN response on RMS API /devices​/credit with all scopes enabled - Crowd Support Forum | Teltonika Networks
When I try a PUT request to /devices​/credit with a payload like
“data”: [
“device_id”: xx,
“auto_extend_credit”: false,
I get the response: forbidden. I checked other commands (like for example get devices) and they work fine.
Why is this so - why is this command forbidden? Any ideas?
You are most likely missing permissions or scopes to access/edit credit information. If you have administrator access to the RMS account, make sure everything credit-related is enabled for this API token.
Hi Daumantas,
you are absolutely right - it was an issue related to the rights of the API token. After enabling device_credits:write it works. :slight_smile:
thx a lot!!
br,
