FMX150 firmware update
we want to update our FMC150 firmware to the latest newest version 04.01.00.Rev.08, after download the firmware files we founded a document that describe that bootloader and can chip must patched in some conditions.
in our case the FMC150 firmware version is already 03.29.00.Rev.157 and CAN Chip version is 00_02.04.01 .. it is no need to update can chip and bootloader in this case ? can we update firmware directly to 04.01.00.Rev.08 without update CAN Chip and bootloader ?
Also it is possible to update the device firmware when the vehicle engine is ON and moving ? in our case installed on Volvo FM mk3
Hello @hamza,
I hope you are doing well. You may update the device to the latest Firmware version if you found some useful fixed parameters on the latest version. On the other hand, CAN Chip Firmware has also some adjustments and if you need those changes you may update the CAN Chip Firmware at the same time as well.
Fore more information, you may refer on this links below:
FMC150 Firmware errata: FMC150 Firmware Changelog - Teltonika Telematics Wiki
CAN Chip Firmware: FMX150 CAN Chip Firmware Errata - Teltonika Telematics Wiki
Patrick S.
