FMT100 numerous notifications
Our FMT100 trackers are configured to reply from server when Ignition is turned on using sensor IO239=1. However over the past 2 days numerous trackers have been sending many alerts in succesion when vehicle is constantly moving. No settings have been adjusted to trigger this. System has been totally stable until now. ??
Hi Good day,
What is your ignition source?
Accelerometer or Power Voltage?
If you are using an accelerometer as a source, once the movement is detected the ignition status will become true so everytime the vehicle moves you will receive this notification to your server.
Then if you are using the power voltage, you need to measure what is the battery voltage of the vehicle when it is running, and when the ignition is on, configure it according to the LOW and HIGH values from the configurator.
Also, note that the voltage may fluctuate when the vehicle is running.
Regards
Maynard C.
I was using Power Voltage only but have now changed settings to both Power Voltage and Accelerometer.
Hi
If you selected both, If one of the selected sources is true then the ignition status will change to true or 1.
Regards
Maynard C.
