FMM920 won't connect to USA AT&T/T-Mobile LTE-M or NB-IOT. "Modem not ready" error
I am using a soracom sim card which works in other various generic trackers. I want to try Teltonika as it appears to much better software and quality.
I can’t get it to connect. Any tips?
The log is below.Log Enabled for UART[4] [2025.11.24 17:51:22]-[REC.SEND.1] Modem not ready (try 23) [2025.11.24 17:51:23]-[AXL.CLBR] Earth acc data updated (3528/15) [2025.11.24 17:51:24]-[AXL.CLBR] Earth acc data updated (3529/15) [2025.11.24 17:51:24]-[REC.SEND.1] Modem not ready (try 22) [2025.11.24 17:51:25]-[AXL.CLBR] Earth acc data updated (3530/15) [2025.11.24 17:51:26]-[AXL.CLBR] Earth acc data updated (3531/15) [2025.11.24 17:51:26]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 98 / 120 [2025.11.24 17:51:26]-[REC.SEND.1] Modem not ready (try 21) [2025.11.24 17:51:27]-[AXL.CLBR] Earth acc data updated (3532/15) [2025.11.24 17:51:27]-[AXL.CLBR] Collecting AXL data! Cnt:3535 Straight:0 Ground:3532 [2025.11.24 17:51:27]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:51:27]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:51:27]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13910 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:51:28]-[AXL.CLBR] Earth acc data updated (3533/15) [2025.11.24 17:51:28]-[OVERSPD] Scenario disabled! [2025.11.24 17:51:28]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:51 Limit:1800 [2025.11.24 17:51:28]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1150 Limit:5400* [2025.11.24 17:51:28]-[REC.SEND.1] Modem not ready (try 20) [2025.11.24 17:51:29]-[AXL.CLBR] Earth acc data updated (3534/15) [2025.11.24 17:51:30]-[AXL.CLBR] Earth acc data updated (3535/15) [2025.11.24 17:51:30]-[REC.SEND.1] Modem not ready (try 19) [2025.11.24 17:51:31]-[AXL.CLBR] Earth acc data updated (3536/15) [2025.11.24 17:51:32]-[AXL.CLBR] Earth acc data updated (3537/15) [2025.11.24 17:51:32]-[AXL.CLBR] Collecting AXL data! Cnt:3540 Straight:0 Ground:3537 [2025.11.24 17:51:32]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 104 / 120 [2025.11.24 17:51:32]-[REC.SEND.1] Modem not ready (try 18) [2025.11.24 17:51:33]-[AXL.CLBR] Earth acc data updated (3538/15) [2025.11.24 17:51:34]-[AXL.CLBR] Earth acc data updated (3539/15) [2025.11.24 17:51:34]-[REC.SEND.1] Modem not ready (try 17) [2025.11.24 17:51:35]-[AXL.CLBR] Earth acc data updated (3540/15) [2025.11.24 17:51:35]-[APN.LIST] AutoAPN save count: 0 [2025.11.24 17:51:35]-[GPS.TEST] [GPS.DATA] gps state: ON status FIX: 1 No fix reason: 0 moment RMC status: A moment GGA quality: 1 moment latitude: 47.342925, good latitude: 47.342925 moment longitude: -122.105845, good longitude: -122.105845 moment altitude: 145.900000, good altitude: 145.900000 moment speed: 0.000000, good speed: 0.000000 moment angle: 2.410000, good angle: 2.410000 moment gps sats in view/use: 9/9 moment galileo sats in view/use: 0/0 moment glonass sats in view/use: 9/5 moment beidou sats in view/use: 0/0 moment total GSV sats in view: 18 moment total GSA sats in use: 14 status time: 17:51:35 status date: 2025.11.24 GPS init status: 3 moment avg pdop: 1.350000 moment avg hdop: 0.740000 moment accuracy: 4.100000 fw version: MT3333_AXN_5.1.9_MT2503_STD_F0,0000, GNSS system: GPS GLONASS nmea data captured: 3593 nmea stability: 1 SN mode: 1 gps flashing: 0 version state: 3 [2025.11.24 17:51:36]-[AXL.CLBR] Earth acc data updated (3541/15) [2025.11.24 17:51:36]-[REC.SEND.1] Modem not ready (try 16) [2025.11.24 17:51:37]-[AXL.CLBR] Earth acc data updated (3542/15) [2025.11.24 17:51:37]-[AXL.CLBR] Collecting AXL data! Cnt:3545 Straight:0 Ground:3542 [2025.11.24 17:51:37]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:51:38]-[AXL.CLBR] Earth acc data updated (3543/15) [2025.11.24 17:51:38]-[OVERSPD] Scenario disabled! [2025.11.24 17:51:38]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:61 Limit:1800 [2025.11.24 17:51:38]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1160 Limit:5400* [2025.11.24 17:51:38]-[REC.SEND.1] Modem not ready (try 15) [2025.11.24 17:51:39]-[AXL.CLBR] Earth acc data updated (3544/15) [2025.11.24 17:51:40]-[AXL.CLBR] Earth acc data updated (3545/15) [2025.11.24 17:51:40]-[REC.SEND.1] Modem not ready (try 14) [2025.11.24 17:51:41]-[AXL.CLBR] Earth acc data updated (3546/15) [2025.11.24 17:51:42]-[AXL.CLBR] Earth acc data updated (3547/15) [2025.11.24 17:51:42]-[AXL.CLBR] Collecting AXL data! Cnt:3550 Straight:0 Ground:3547 [2025.11.24 17:51:42]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 114 / 120 [2025.11.24 17:51:42]-[REC.SEND.1] Modem not ready (try 13) [2025.11.24 17:51:43]-[AXL.CLBR] Earth acc data updated (3548/15) [2025.11.24 17:51:44]-[AXL.CLBR] Earth acc data updated (3549/15) [2025.11.24 17:51:44]-[REC.SEND.1] Modem not ready (try 12) [2025.11.24 17:51:45]-[AXL.CLBR] Earth acc data updated (3550/15) [2025.11.24 17:51:46]-[AXL.CLBR] Earth acc data updated (3551/15) [2025.11.24 17:51:46]-[REC.SEND.1] Modem not ready (try 11) [2025.11.24 17:51:47]-[AXL.CLBR] Earth acc data updated (3552/15) [2025.11.24 17:51:47]-[AXL.CLBR] Collecting AXL data! Cnt:3555 Straight:0 Ground:3552 [2025.11.24 17:51:47]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:51:48]-[AXL.CLBR] Earth acc data updated (3553/15) [2025.11.24 17:51:48]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:51:48]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:51:48]-[ATCMD] <<AT+CPAS [2025.11.24 17:51:48]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:51:48]-[ATCMD] >>[134] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+CIMI [2025.11.24 17:51:48]-[OVERSPD] Scenario disabled! [2025.11.24 17:51:48]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:51:48]-[ATCMD] >>[172] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+CGREG? [2025.11.24 17:51:48]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:51:48]-[AT.RSP] Status: 4 [2025.11.24 17:51:48]-[AT.RSP] Unknown [2025.11.24 17:51:48]-[ATCMD] >>[140] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+CEREG? [2025.11.24 17:51:48]-[ATCMD] >>[141] +CEREG: 2,3 [2025.11.24 17:51:48]-[ATCMD] >>[141] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+QGMR [2025.11.24 17:51:48]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:51:48]-[ATCMD] >>[167] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+QCSQ [2025.11.24 17:51:48]-[ATCMD] >>[132] +QCSQ: “NBIoT”,-76,-89,132,-12 [2025.11.24 17:51:48]-[AT.RSP] #RAT: “NBIoT” [2025.11.24 17:51:48]-[AT.RSP] #RSSI: -76 dBm [2025.11.24 17:51:48]-[AT.RSP] #RSRP: -89 dBm [2025.11.24 17:51:48]-[AT.RSP] #SINR: 6.4 dB [2025.11.24 17:51:48]-[AT.RSP] #RSRQ: -12 dB [2025.11.24 17:51:48]-[ATCMD] >>[132] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:51:48]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:71 Limit:1800 [2025.11.24 17:51:48]-[ATCMD] >>[133] +QNWINFO: “NBIoT”,“311480”,“LTE BAND 13”,5184 [2025.11.24 17:51:48]-[ATCMD] >>[133] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+CSQ [2025.11.24 17:51:48]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1170 Limit:5400* [2025.11.24 17:51:48]-[ATCMD] >>[131] +CSQ: 19,99 [2025.11.24 17:51:48]-[ATCMD] >>[131] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+CFUN? [2025.11.24 17:51:48]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:51:48]-[ATCMD] >>[151] OK [2025.11.24 17:51:48]-[ATCMD] <<AT+COPS? [2025.11.24 17:51:48]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:51:48]-[ATCMD] >>[135] OK [2025.11.24 17:51:48]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:51:48]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:55/81 [2025.11.24 17:51:48]-[REC.SEND.1] Modem not ready (try 10) [2025.11.24 17:51:49]-[AXL.CLBR] Earth acc data updated (3554/15) [2025.11.24 17:51:50]-[AXL.CLBR] Earth acc data updated (3555/15) [2025.11.24 17:51:50]-[OBDII] OBD Disabled (1 0) Write Counters: c:@system\odometer:0 c:@system\simcard:0 c:@system\fuelcons:0 c:@system\position:0 c:@system\secur:0 c:@system\noncfgpars:25 ------------------------ NOR Block erase cycles ----------------------- | ID - Erases | | ID - Erases | | ID - Erases | | ID - Erases | ----------------------------------------------------------------------- | 0 - 7 | | 1 - 3 | | 2 - 9 | | 3 - 1 | | 4 - 2 | | 5 - 6 | | 6 - 9 | | 7 - 9 | | 8 - 9 | | 9 - 8 | | 10 - 7 | | 11 - 7 | | 12 - 7 | | 13 - 9 | | 14 - 4 | | 15 - 2 | | 16 - 1 | | 17 - 2 | | 18 - 8 | | 19 - 8 | | 20 - 7 | | 21 - 8 | | 22 - 8 | | 23 - 1 | | 24 - 8 | | 25 - 1 | | 26 - 1 | | 27 - 1 | | 28 - 7 | | 29 - 8 | | 30 - 1 | | 31 - 8 | | 32 - 1 | | 33 - 1 | | 34 - 1 | | 35 - 1 | | 36 - 8 | | 37 - 5 | | 38 - 1 | | 39 - 5 | | 40 - 8 | | 41 - 1 | | 42 - 2 | | 43 - 8 | | 44 - 1 | | 45 - 1 | | 46 - 1 | | 47 - 8 | | 48 - 8 | | 49 - 1 | | 50 - 1 | | 51 - 1 | | 52 - 1 | | 53 - 1 | | 54 - 1 | | 55 - 1 | | 56 - 1 | | 57 - 1 | | 58 - 1 | | 59 - 1 | | 60 - 1 | | 61 - 1 | | 62 - 1 | | 63 - 1 | | 64 - 1 | | 65 - 1 | | 66 - 6 | | 67 - 8 | | 68 - 8 | | 69 - 1 | | 70 - 8 | | 71 - 2 | | 72 - 1 | | 73 - 1 | | 74 - 1 | | 75 - 7 | | 76 - 1 | | 77 - 8 | | 78 - 8 | | 79 - 8 | | 80 - 9 | | 81 - 1 | | 82 - 9 | | 83 - 8 | | 84 - 8 | | 85 - 8 | | 86 - 8 | | 87 - 8 | | 88 - 8 | | 89 - 6 | | 90 - 8 | | 91 - 6 | | 92 - 8 | | 93 - 6 | | 94 - 8 | | 95 - 8 | | 96 - 9 | | 97 - 8 | | 98 - 9 | | 99 - 8 | | 100 - 8 | | 101 - 9 | | 102 - 9 | | 103 - 4 | | 104 - 7 | | 105 - 9 | | 106 - 9 | | 107 - 5 | | 108 - 8 | | 109 - 8 | ----------------------------------------------------------------------- [2025.11.24 17:51:50]-[MODEM] *** RAT Uptime *** System uptime: 0d 1h 0min 2s #UNKNOWN: 0d 9h 27min 42s [2025.11.24 17:51:50]-[REC.SEND.1] Modem not ready (try 9) [2025.11.24 17:51:51]-[AXL.CLBR] Earth acc data updated (3556/15) [2025.11.24 17:51:52]-[AXL.CLBR] Earth acc data updated (3557/15) [2025.11.24 17:51:52]-[AXL.CLBR] Collecting AXL data! Cnt:3560 Straight:0 Ground:3557 [2025.11.24 17:51:52]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 4 / 120 [2025.11.24 17:51:52]-[REC.SEND.1] Modem not ready (try 8) [2025.11.24 17:51:53]-[AXL.CLBR] Earth acc data updated (3558/15) [2025.11.24 17:51:54]-[AXL.CLBR] Earth acc data updated (3559/15) [2025.11.24 17:51:54]-[REC.SEND.1] Modem not ready (try 7) [2025.11.24 17:51:55]-[AXL.CLBR] Earth acc data updated (3560/15) [2025.11.24 17:51:56]-[AXL.CLBR] Earth acc data updated (3561/15) [2025.11.24 17:51:56]-[REC.SEND.1] Modem not ready (try 6) [2025.11.24 17:51:57]-[AXL.CLBR] Earth acc data updated (3562/15) [2025.11.24 17:51:57]-[AXL.CLBR] Collecting AXL data! Cnt:3565 Straight:0 Ground:3562 [2025.11.24 17:51:57]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:51:57]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:51:57]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13906 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:51:58]-[AXL.CLBR] Earth acc data updated (3563/15) [2025.11.24 17:51:58]-[OVERSPD] Scenario disabled! [2025.11.24 17:51:58]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:81 Limit:1800 [2025.11.24 17:51:58]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1180 Limit:5400* [2025.11.24 17:51:58]-[REC.SEND.1] Modem not ready (try 5) [2025.11.24 17:51:59]-[AXL.CLBR] Earth acc data updated (3564/15) [2025.11.24 17:52:00]-[AXL.CLBR] Earth acc data updated (3565/15) [2025.11.24 17:52:00]-[REC.SEND.1] Modem not ready (try 4) [2025.11.24 17:52:01]-[AXL.CLBR] Earth acc data updated (3566/15) [2025.11.24 17:52:02]-[AXL.CLBR] Earth acc data updated (3567/15) [2025.11.24 17:52:02]-[AXL.CLBR] Collecting AXL data! Cnt:3570 Straight:0 Ground:3567 [2025.11.24 17:52:02]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 14 / 120 [2025.11.24 17:52:02]-[REC.SEND.1] Modem not ready (try 3) [2025.11.24 17:52:03]-[AXL.CLBR] Earth acc data updated (3568/15) [2025.11.24 17:52:04]-[AXL.CLBR] Earth acc data updated (3569/15) [2025.11.24 17:52:04]-[REC.SEND.1] Modem not ready (try 2) [2025.11.24 17:52:05]-[AXL.CLBR] Earth acc data updated (3570/15) [2025.11.24 17:52:05]-[ADC] Values Table: [Core V ]: 1.000 (3861) 0 [External V]: 16.000 (13906) 470 [Battery V ]: 1.727 (4114) 0 [Ch. current]: 0.071 (0) 0 [Ain1 ]: 16.000 (0) 0 [NTC ]: 1.000 (1747) 0 Using Conv Table:FMB9XX CalibVals:1 [2025.11.24 17:52:06]-[AXL.CLBR] Earth acc data updated (3571/15) [2025.11.24 17:52:06]-[REC.SEND.1] Modem not ready (try 1) [2025.11.24 17:52:07]-[AXL.CLBR] Earth acc data updated (3572/15) [2025.11.24 17:52:07]-[AXL.CLBR] Collecting AXL data! Cnt:3575 Straight:0 Ground:3572 [2025.11.24 17:52:07]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:52:08]-[AXL.CLBR] Earth acc data updated (3573/15) [2025.11.24 17:52:08]-[OVERSPD] Scenario disabled! [2025.11.24 17:52:08]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:91 Limit:1800 [2025.11.24 17:52:08]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1190 Limit:5400* [2025.11.24 17:52:08]-[REC.SEND.1] Modem not ready (try 0) [2025.11.24 17:52:08]-[REC.SEND.1] [CHANGE.STATE.0548] Server: 0, check gprs => finished [2025.11.24 17:52:08]-[REC.SEND.1] finished [2025.11.24 17:52:08]-[REC.SEND.1] Server[0] RELEASED processor sleep handle [2025.11.24 17:52:09]-[AXL.CLBR] Earth acc data updated (3574/15) [2025.11.24 17:52:10]-[AXL.CLBR] Earth acc data updated (3575/15) [2025.11.24 17:52:11]-[AXL.CLBR] Earth acc data updated (3576/15) [2025.11.24 17:52:12]-[AXL.CLBR] Earth acc data updated (3577/15) [2025.11.24 17:52:12]-[AXL.CLBR] Collecting AXL data! Cnt:3580 Straight:0 Ground:3577 [2025.11.24 17:52:12]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 24 / 120 [2025.11.24 17:52:13]-[AXL.CLBR] Earth acc data updated (3578/15) [2025.11.24 17:52:14]-[AXL.CLBR] Earth acc data updated (3579/15) [2025.11.24 17:52:15]-[AXL.CLBR] Earth acc data updated (3580/15) [2025.11.24 17:52:16]-[AXL.CLBR] Earth acc data updated (3581/15) [2025.11.24 17:52:17]-[AXL.CLBR] Earth acc data updated (3582/15) [2025.11.24 17:52:17]-[AXL.CLBR] Collecting AXL data! Cnt:3585 Straight:0 Ground:3582 [2025.11.24 17:52:17]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:52:18]-[AXL.CLBR] Earth acc data updated (3583/15) [2025.11.24 17:52:18]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:52:18]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:52:18]-[ATCMD] <<AT+CPAS [2025.11.24 17:52:18]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:52:18]-[ATCMD] >>[134] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+CIMI [2025.11.24 17:52:18]-[OVERSPD] Scenario disabled! [2025.11.24 17:52:18]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:52:18]-[ATCMD] >>[172] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+CGREG? [2025.11.24 17:52:18]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:52:18]-[AT.RSP] Status: 4 [2025.11.24 17:52:18]-[AT.RSP] Unknown [2025.11.24 17:52:18]-[ATCMD] >>[140] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+CEREG? [2025.11.24 17:52:18]-[ATCMD] >>[141] +CEREG: 2,3 [2025.11.24 17:52:18]-[ATCMD] >>[141] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+QGMR [2025.11.24 17:52:18]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:52:18]-[ATCMD] >>[167] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+QCSQ [2025.11.24 17:52:18]-[ATCMD] >>[132] +QCSQ: “NBIoT”,-76,-89,132,-12 [2025.11.24 17:52:18]-[AT.RSP] #RAT: “NBIoT” [2025.11.24 17:52:18]-[AT.RSP] #RSSI: -76 dBm [2025.11.24 17:52:18]-[AT.RSP] #RSRP: -89 dBm [2025.11.24 17:52:18]-[AT.RSP] #SINR: 6.4 dB [2025.11.24 17:52:18]-[AT.RSP] #RSRQ: -12 dB [2025.11.24 17:52:18]-[ATCMD] >>[132] OK [2025.11.24 17:52:18]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:101 Limit:1800 [2025.11.24 17:52:18]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:52:18]-[ATCMD] >>[133] +QNWINFO: “NBIoT”,“311480”,“LTE BAND 13”,5184 [2025.11.24 17:52:18]-[ATCMD] >>[133] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+CSQ [2025.11.24 17:52:18]-[ATCMD] >>[131] +CSQ: 19,99 [2025.11.24 17:52:18]-[ATCMD] >>[131] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+CFUN? [2025.11.24 17:52:18]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:52:18]-[ATCMD] >>[151] OK [2025.11.24 17:52:18]-[ATCMD] <<AT+COPS? [2025.11.24 17:52:18]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:52:18]-[ATCMD] >>[135] OK [2025.11.24 17:52:18]-[REC.SEND.1] Caller: 0718, queueing recsend1 task job type: 6/force open link [2025.11.24 17:52:18]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:52:18]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:56/81 [2025.11.24 17:52:18]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1200 Limit:5400* [2025.11.24 17:52:18]-[REC.SEND.1] [CHANGE.STATE.0276] Server: 0, finished => check gprs [2025.11.24 17:52:18]-[REC.SEND.1] check gprs [2025.11.24 17:52:18]-[REC.SEND.1] Modem not ready (try 69) [2025.11.24 17:52:19]-[AXL.CLBR] Earth acc data updated (3584/15) [2025.11.24 17:52:20]-[AXL.CLBR] Earth acc data updated (3585/15) [2025.11.24 17:52:20]-[SYS.DIAG] Code Version:04.00.00 Code Rev:13 IMEI: 862406076295233 HW ver: FMM920 HW mod: 1 HW volt:554mV HW tbl: 8 BL ver: 1.10 BLE: 1 NAND: 1 AXL: 1/LIS3DH BT ADDR:{38:8A:21:C3:E1:EB} Started:2025-11-24 16:51 Uptime: 0d 1h 0min 32s PWR rsn:SoftReset Cnt:0 Abn:0 Mode:Unknown on Stop SpcId:1 UpdRes:-65536 Calib: Empty Run: 1 Qual: 0.00 Dbg: 0 Iter: 3589,0 G{0.000000;0.000000;0.000000} R{0.000000;0.000000;0.000000} MAP{0.000000;0.000000;0.000000} DynZ{0.018822;-0.021737;1.041130} GPS Fix: 1 No fix reason: 0 GPS state: 1 TTFF: 8s TTLF: 5s NoFix: 0s Latitude :47.342925 Longitude:-122.105845 Altitude :145 FW Ver: AXN_5.1.9 SN mode: 1 TSYNC: Last Sync:GPS at 1763997456s, NTP cnt:0, Fails:0 [2025.11.24 17:52:20]-[REC.SEND.1] Modem not ready (try 68) [2025.11.24 17:52:21]-[AXL.CLBR] Earth acc data updated (3586/15) [2025.11.24 17:52:22]-[AXL.CLBR] Earth acc data updated (3587/15) [2025.11.24 17:52:22]-[AXL.CLBR] Collecting AXL data! Cnt:3590 Straight:0 Ground:3587 [2025.11.24 17:52:22]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 34 / 120 [2025.11.24 17:52:22]-[REC.SEND.1] Modem not ready (try 67) [2025.11.24 17:52:23]-[AXL.CLBR] Earth acc data updated (3588/15) [2025.11.24 17:52:24]-[AXL.CLBR] Earth acc data updated (3589/15) [2025.11.24 17:52:24]-[REC.SEND.1] Modem not ready (try 66) [2025.11.24 17:52:25]-[AXL.CLBR] Earth acc data updated (3590/15) [2025.11.24 17:52:26]-[AXL.CLBR] Earth acc data updated (3591/15) [2025.11.24 17:52:26]-[REC.SEND.1] Modem not ready (try 65) [2025.11.24 17:52:27]-[AXL.CLBR] Earth acc data updated (3592/15) [2025.11.24 17:52:27]-[AXL.CLBR] Collecting AXL data! Cnt:3595 Straight:0 Ground:3592 [2025.11.24 17:52:27]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:52:27]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:52:27]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13912 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:52:28]-[AXL.CLBR] Earth acc data updated (3593/15) [2025.11.24 17:52:28]-[OVERSPD] Scenario disabled! [2025.11.24 17:52:28]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:111 Limit:1800 [2025.11.24 17:52:28]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1210 Limit:5400* [2025.11.24 17:52:28]-[REC.SEND.1] Modem not ready (try 64) [2025.11.24 17:52:29]-[AXL.CLBR] Earth acc data updated (3594/15) [2025.11.24 17:52:30]-[AXL.CLBR] Earth acc data updated (3595/15) [2025.11.24 17:52:30]-[REC.SEND.1] Modem not ready (try 63) [2025.11.24 17:52:31]-[AXL.CLBR] Earth acc data updated (3596/15) [2025.11.24 17:52:32]-[AXL.CLBR] Earth acc data updated (3597/15) [2025.11.24 17:52:32]-[AXL.CLBR] Collecting AXL data! Cnt:3600 Straight:0 Ground:3597 [2025.11.24 17:52:32]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 44 / 120 [2025.11.24 17:52:32]-[REC.SEND.1] Modem not ready (try 62) [2025.11.24 17:52:33]-[AXL.CLBR] Earth acc data updated (3598/15) [2025.11.24 17:52:33]-[LiPo] ERROR @ m2m_charger_lipo.c(1283):Battery percentage stuck, redoing percentage calculation [2025.11.24 17:52:34]-[AXL.CLBR] Earth acc data updated (3599/15) [2025.11.24 17:52:34]-[REC.SEND.1] Modem not ready (try 61) [2025.11.24 17:52:35]-[AXL.CLBR] Earth acc data updated (3600/15) [MODEM.STATUS] CCID : 8942310223002516340 IMSI : 295050915745634 Data Link : 0/0/0/0/0/0 GPRS Status : 0 Phone Status: 0 PIN Attempts : 3,3 GSM Operator: 0 Bat. Charge : 0 GSM Signal : 4 Service : 0 New Message : 0 Roaming : 0 SMS Full : 0 Voice Call : 0 LAC : 0 Cell ID : 0 CFUN : 1 CSQ (rssi) : 19 QCSQ (rssi) : -76 dBm QCSQ (rsrp) : -89 dBm QCSQ (sinr) : 6.4 dB QCSQ (rsrq) : -12 dB [0]SIM detected: 1 Network Type: 99/UNKNOWN Current LTE BAND: 13 Modem (Relative / Absolute): StPin fails : 0 / 0 AT dead cnt : 0 / 0 Init fails : 0 / 0 [2025.11.24 17:52:36]-[AXL.CLBR] Earth acc data updated (3601/15) [2025.11.24 17:52:36]-[REC.SEND.1] Modem not ready (try 60) [2025.11.24 17:52:37]-[AXL.CLBR] Earth acc data updated (3602/15) [2025.11.24 17:52:37]-[AXL.CLBR] Collecting AXL data! Cnt:3605 Straight:0 Ground:3602 [2025.11.24 17:52:37]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:52:38]-[AXL.CLBR] Earth acc data updated (3603/15) [2025.11.24 17:52:38]-[OVERSPD] Scenario disabled! [2025.11.24 17:52:38]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:121 Limit:1800 [2025.11.24 17:52:38]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1220 Limit:5400* [2025.11.24 17:52:38]-[REC.SEND.1] Modem not ready (try 59) [2025.11.24 17:52:39]-[AXL.CLBR] Earth acc data updated (3604/15) [2025.11.24 17:52:40]-[AXL.CLBR] Earth acc data updated (3605/15) [2025.11.24 17:52:40]-[REC.SEND.1] Modem not ready (try 58) [2025.11.24 17:52:41]-[AXL.CLBR] Earth acc data updated (3606/15) [2025.11.24 17:52:42]-[AXL.CLBR] Earth acc data updated (3607/15) [2025.11.24 17:52:42]-[AXL.CLBR] Collecting AXL data! Cnt:3610 Straight:0 Ground:3607 [2025.11.24 17:52:42]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 54 / 120 [2025.11.24 17:52:42]-[REC.SEND.1] Modem not ready (try 57) [2025.11.24 17:52:43]-[AXL.CLBR] Earth acc data updated (3608/15) [2025.11.24 17:52:44]-[AXL.CLBR] Earth acc data updated (3609/15) [2025.11.24 17:52:44]-[REC.SEND.1] Modem not ready (try 56) [2025.11.24 17:52:45]-[AXL.CLBR] Earth acc data updated (3610/15) [2025.11.24 17:52:46]-[AXL.CLBR] Earth acc data updated (3611/15) [2025.11.24 17:52:46]-[REC.SEND.1] Modem not ready (try 55) [2025.11.24 17:52:47]-[AXL.CLBR] Earth acc data updated (3612/15) [2025.11.24 17:52:47]-[AXL.CLBR] Collecting AXL data! Cnt:3615 Straight:0 Ground:3612 [2025.11.24 17:52:47]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:52:48]-[AXL.CLBR] Earth acc data updated (3613/15) [2025.11.24 17:52:48]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:52:48]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:52:48]-[ATCMD] <<AT+CPAS [2025.11.24 17:52:48]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:52:48]-[ATCMD] >>[134] OK [2025.11.24 17:52:48]-[OVERSPD] Scenario disabled! [2025.11.24 17:52:48]-[ATCMD] <<AT+CIMI [2025.11.24 17:52:48]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:52:48]-[ATCMD] >>[172] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+CGREG? [2025.11.24 17:52:48]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:52:48]-[AT.RSP] Status: 4 [2025.11.24 17:52:48]-[AT.RSP] Unknown [2025.11.24 17:52:48]-[ATCMD] >>[140] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+CEREG? [2025.11.24 17:52:48]-[ATCMD] >>[141] +CEREG: 2,3 [2025.11.24 17:52:48]-[ATCMD] >>[141] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+QGMR [2025.11.24 17:52:48]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:52:48]-[ATCMD] >>[167] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+QCSQ [2025.11.24 17:52:48]-[ATCMD] >>[132] +QCSQ: “NBIoT”,-76,-89,132,-12 [2025.11.24 17:52:48]-[AT.RSP] #RAT: “NBIoT” [2025.11.24 17:52:48]-[AT.RSP] #RSSI: -76 dBm [2025.11.24 17:52:48]-[AT.RSP] #RSRP: -89 dBm [2025.11.24 17:52:48]-[AT.RSP] #SINR: 6.4 dB [2025.11.24 17:52:48]-[AT.RSP] #RSRQ: -12 dB [2025.11.24 17:52:48]-[ATCMD] >>[132] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:52:48]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:131 Limit:1800 [2025.11.24 17:52:48]-[ATCMD] >>[133] +QNWINFO: “NBIoT”,“310260”,“LTE BAND 12”,5035 [2025.11.24 17:52:48]-[ATCMD] >>[133] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+CSQ [2025.11.24 17:52:48]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1230 Limit:5400* [2025.11.24 17:52:48]-[ATCMD] >>[131] +CSQ: 19,99 [2025.11.24 17:52:48]-[ATCMD] >>[131] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+CFUN? [2025.11.24 17:52:48]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:52:48]-[ATCMD] >>[151] OK [2025.11.24 17:52:48]-[ATCMD] <<AT+COPS? [2025.11.24 17:52:48]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:52:48]-[ATCMD] >>[135] OK [2025.11.24 17:52:48]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:52:48]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:57/81 [2025.11.24 17:52:48]-[REC.SEND.1] Modem not ready (try 54) [2025.11.24 17:52:49]-[AXL.CLBR] Earth acc data updated (3614/15) [2025.11.24 17:52:50]-[AXL.CLBR] Earth acc data updated (3615/15) [2025.11.24 17:52:50]-[BLE.APP] bt init: 1, ble init: 1, sens en: 0, cnt: 0/30, listen: 1, broadcast: 1/0x0000 [2025.11.24 17:52:50]-[BLE.APP] [00] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:52:50]-[BLE.APP] [01] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:52:50]-[BLE.APP] [02] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:52:50]-[BLE.APP] [03] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:52:50]-[BLE.APP] ble scan status: 0, caller status: 0/?, unlimited: 0 [2025.11.24 17:52:50]-[REC.SEND.1] Modem not ready (try 53) [2025.11.24 17:52:51]-[AXL.CLBR] Earth acc data updated (3616/15) [2025.11.24 17:52:52]-[AXL.CLBR] Earth acc data updated (3617/15) [2025.11.24 17:52:52]-[AXL.CLBR] Collecting AXL data! Cnt:3620 Straight:0 Ground:3617 [2025.11.24 17:52:52]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 64 / 120 [2025.11.24 17:52:52]-[REC.SEND.1] Modem not ready (try 52) [2025.11.24 17:52:53]-[AXL.CLBR] Earth acc data updated (3618/15) [2025.11.24 17:52:54]-[AXL.CLBR] Earth acc data updated (3619/15) [2025.11.24 17:52:54]-[REC.SEND.1] Modem not ready (try 51) [2025.11.24 17:52:55]-[AXL.CLBR] Earth acc data updated (3620/15) [2025.11.24 17:52:56]-[AXL.CLBR] Earth acc data updated (3621/15) [2025.11.24 17:52:56]-[REC.SEND.1] Modem not ready (try 50) [2025.11.24 17:52:57]-[AXL.CLBR] Earth acc data updated (3622/15) [2025.11.24 17:52:57]-[AXL.CLBR] Collecting AXL data! Cnt:3625 Straight:0 Ground:3622 [2025.11.24 17:52:57]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:52:57]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:52:57]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13919 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:52:58]-[AXL.CLBR] Earth acc data updated (3623/15) [2025.11.24 17:52:58]-[OVERSPD] Scenario disabled! [2025.11.24 17:52:58]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:141 Limit:1800 [2025.11.24 17:52:58]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1240 Limit:5400* [2025.11.24 17:52:58]-[REC.SEND.1] Modem not ready (try 49) [2025.11.24 17:52:59]-[AXL.CLBR] Earth acc data updated (3624/15) [2025.11.24 17:53:00]-[AXL.CLBR] Earth acc data updated (3625/15) [2025.11.24 17:53:00]-[REC.SEND.1] Modem not ready (try 48) [2025.11.24 17:53:01]-[AXL.CLBR] Earth acc data updated (3626/15) [2025.11.24 17:53:02]-[AXL.CLBR] Earth acc data updated (3627/15) [2025.11.24 17:53:02]-[AXL.CLBR] Collecting AXL data! Cnt:3630 Straight:0 Ground:3627 [2025.11.24 17:53:02]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 74 / 120 [2025.11.24 17:53:02]-[REC.SEND.1] Modem not ready (try 47) [2025.11.24 17:53:03]-[AXL.CLBR] Earth acc data updated (3628/15) [2025.11.24 17:53:04]-[AXL.CLBR] Earth acc data updated (3629/15) [2025.11.24 17:53:04]-[REC.SEND.1] Modem not ready (try 46) [2025.11.24 17:53:05]-[AXL.CLBR] Earth acc data updated (3630/15) [2025.11.24 17:53:05]-[APN.LIST] AutoAPN save count: 0 [2025.11.24 17:53:05]-[GPS.TEST] [GPS.DATA] gps state: ON status FIX: 1 No fix reason: 0 moment RMC status: A moment GGA quality: 1 moment latitude: 47.342925, good latitude: 47.342925 moment longitude: -122.105845, good longitude: -122.105845 moment altitude: 145.900000, good altitude: 145.900000 moment speed: 0.000000, good speed: 0.000000 moment angle: 2.410000, good angle: 2.410000 moment gps sats in view/use: 9/9 moment galileo sats in view/use: 0/0 moment glonass sats in view/use: 8/5 moment beidou sats in view/use: 0/0 moment total GSV sats in view: 17 moment total GSA sats in use: 14 status time: 17:53:05 status date: 2025.11.24 GPS init status: 3 moment avg pdop: 1.350000 moment avg hdop: 0.740000 moment accuracy: 3.900000 fw version: MT3333_AXN_5.1.9_MT2503_STD_F0,0000, GNSS system: GPS GLONASS nmea data captured: 3683 nmea stability: 1 SN mode: 1 gps flashing: 0 version state: 3 [2025.11.24 17:53:06]-[AXL.CLBR] Earth acc data updated (3631/15) [2025.11.24 17:53:06]-[REC.SEND.1] Modem not ready (try 45) [2025.11.24 17:53:07]-[AXL.CLBR] Earth acc data updated (3632/15) [2025.11.24 17:53:07]-[AXL.CLBR] Collecting AXL data! Cnt:3635 Straight:0 Ground:3632 [2025.11.24 17:53:07]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:53:08]-[AXL.CLBR] Earth acc data updated (3633/15) [2025.11.24 17:53:08]-[OVERSPD] Scenario disabled! [2025.11.24 17:53:08]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:151 Limit:1800 [2025.11.24 17:53:08]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1250 Limit:5400* [2025.11.24 17:53:08]-[REC.SEND.1] Modem not ready (try 44) [2025.11.24 17:53:09]-[AXL.CLBR] Earth acc data updated (3634/15) [2025.11.24 17:53:10]-[AXL.CLBR] Earth acc data updated (3635/15) [2025.11.24 17:53:10]-[REC.SEND.1] Modem not ready (try 43) [2025.11.24 17:53:11]-[AXL.CLBR] Earth acc data updated (3636/15) [2025.11.24 17:53:12]-[AXL.CLBR] Earth acc data updated (3637/15) [2025.11.24 17:53:12]-[AXL.CLBR] Collecting AXL data! Cnt:3640 Straight:0 Ground:3637 [2025.11.24 17:53:12]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 84 / 120 [2025.11.24 17:53:12]-[REC.SEND.1] Modem not ready (try 42) [2025.11.24 17:53:13]-[AXL.CLBR] Earth acc data updated (3638/15) [2025.11.24 17:53:14]-[AXL.CLBR] Earth acc data updated (3639/15) [2025.11.24 17:53:14]-[REC.SEND.1] Modem not ready (try 41) [2025.11.24 17:53:15]-[AXL.CLBR] Earth acc data updated (3640/15) [2025.11.24 17:53:16]-[AXL.CLBR] Earth acc data updated (3641/15) [2025.11.24 17:53:16]-[REC.SEND.1] Modem not ready (try 40) [2025.11.24 17:53:17]-[AXL.CLBR] Earth acc data updated (3642/15) [2025.11.24 17:53:17]-[AXL.CLBR] Collecting AXL data! Cnt:3645 Straight:0 Ground:3642 [2025.11.24 17:53:17]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:53:18]-[AXL.CLBR] Earth acc data updated (3643/15) [2025.11.24 17:53:18]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:53:18]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:53:18]-[ATCMD] <<AT+CPAS [2025.11.24 17:53:18]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:53:18]-[ATCMD] >>[134] OK [2025.11.24 17:53:18]-[OVERSPD] Scenario disabled! [2025.11.24 17:53:18]-[ATCMD] <<AT+CIMI [2025.11.24 17:53:18]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:53:18]-[ATCMD] >>[172] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+CGREG? [2025.11.24 17:53:18]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:53:18]-[AT.RSP] Status: 4 [2025.11.24 17:53:18]-[AT.RSP] Unknown [2025.11.24 17:53:18]-[ATCMD] >>[140] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+CEREG? [2025.11.24 17:53:18]-[ATCMD] >>[141] +CEREG: 2,3 [2025.11.24 17:53:18]-[ATCMD] >>[141] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+QGMR [2025.11.24 17:53:18]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:53:18]-[ATCMD] >>[167] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+QCSQ [2025.11.24 17:53:18]-[ATCMD] >>[132] +QCSQ: “NBIoT”,-87,-120,76,-19 [2025.11.24 17:53:18]-[AT.RSP] #RAT: “NBIoT” [2025.11.24 17:53:18]-[AT.RSP] #RSSI: -87 dBm [2025.11.24 17:53:18]-[AT.RSP] #RSRP: -120 dBm [2025.11.24 17:53:18]-[AT.RSP] #SINR: -4.8 dB [2025.11.24 17:53:18]-[AT.RSP] #RSRQ: -19 dB [2025.11.24 17:53:18]-[ATCMD] >>[132] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:53:18]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:161 Limit:1800 [2025.11.24 17:53:18]-[ATCMD] >>[133] +QNWINFO: “NBIoT”,“310260”,“LTE BAND 12”,5035 [2025.11.24 17:53:18]-[ATCMD] >>[133] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+CSQ [2025.11.24 17:53:18]-[ATCMD] >>[131] +CSQ: 13,99 [2025.11.24 17:53:18]-[ATCMD] >>[131] OK [2025.11.24 17:53:18]-[ATCMD] <<AT+CFUN? [2025.11.24 17:53:18]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:53:18]-[ATCMD] >>[151] OK [2025.11.24 17:53:18]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1260 Limit:5400* [2025.11.24 17:53:18]-[ATCMD] <<AT+COPS? [2025.11.24 17:53:18]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:53:18]-[ATCMD] >>[135] OK [2025.11.24 17:53:18]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:53:18]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:58/81 [2025.11.24 17:53:18]-[REC.SEND.1] Modem not ready (try 39) [2025.11.24 17:53:19]-[AXL.CLBR] Earth acc data updated (3644/15) [2025.11.24 17:53:20]-[AXL.CLBR] Earth acc data updated (3645/15) [2025.11.24 17:53:20]-[OBDII] OBD Disabled (1 0) [2025.11.24 17:53:20]-[REC.SEND.1] Modem not ready (try 38) [2025.11.24 17:53:21]-[AXL.CLBR] Earth acc data updated (3646/15) [2025.11.24 17:53:22]-[AXL.CLBR] Earth acc data updated (3647/15) [2025.11.24 17:53:22]-[AXL.CLBR] Collecting AXL data! Cnt:3650 Straight:0 Ground:3647 [2025.11.24 17:53:22]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 94 / 120 [2025.11.24 17:53:22]-[REC.SEND.1] Modem not ready (try 37) [2025.11.24 17:53:23]-[AXL.CLBR] Earth acc data updated (3648/15) [2025.11.24 17:53:24]-[AXL.CLBR] Earth acc data updated (3649/15) [2025.11.24 17:53:24]-[REC.SEND.1] Modem not ready (try 36) [2025.11.24 17:53:25]-[AXL.CLBR] Earth acc data updated (3650/15) [2025.11.24 17:53:26]-[AXL.CLBR] Earth acc data updated (3651/15) [2025.11.24 17:53:26]-[REC.SEND.1] Modem not ready (try 35) [2025.11.24 17:53:27]-[AXL.CLBR] Earth acc data updated (3652/15) [2025.11.24 17:53:27]-[AXL.CLBR] Collecting AXL data! Cnt:3655 Straight:0 Ground:3652 [2025.11.24 17:53:27]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:53:27]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:53:27]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13921 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:53:28]-[AXL.CLBR] Earth acc data updated (3653/15) [2025.11.24 17:53:28]-[OVERSPD] Scenario disabled! [2025.11.24 17:53:28]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:171 Limit:1800 [2025.11.24 17:53:28]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1270 Limit:5400* [2025.11.24 17:53:28]-[REC.SEND.1] Modem not ready (try 34) [2025.11.24 17:53:29]-[AXL.CLBR] Earth acc data updated (3654/15) [2025.11.24 17:53:30]-[AXL.CLBR] Earth acc data updated (3655/15) [2025.11.24 17:53:30]-[REC.SEND.1] Modem not ready (try 33) [2025.11.24 17:53:31]-[AXL.CLBR] Earth acc data updated (3656/15) [2025.11.24 17:53:32]-[AXL.CLBR] Earth acc data updated (3657/15) [2025.11.24 17:53:32]-[AXL.CLBR] Collecting AXL data! Cnt:3660 Straight:0 Ground:3657 [2025.11.24 17:53:32]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 104 / 120 [2025.11.24 17:53:32]-[REC.SEND.1] Modem not ready (try 32) [2025.11.24 17:53:33]-[AXL.CLBR] Earth acc data updated (3658/15) [2025.11.24 17:53:34]-[AXL.CLBR] Earth acc data updated (3659/15) [2025.11.24 17:53:34]-[REC.SEND.1] Modem not ready (try 31) [2025.11.24 17:53:35]-[AXL.CLBR] Earth acc data updated (3660/15) [2025.11.24 17:53:35]-[ADC] Values Table: [Core V ]: 1.000 (3859) 0 [External V]: 16.000 (13864) 470 [Battery V ]: 1.727 (4114) 0 [Ch. current]: 0.071 (0) 0 [Ain1 ]: 16.000 (0) 0 [NTC ]: 1.000 (1748) 0 Using Conv Table:FMB9XX CalibVals:1 [2025.11.24 17:53:36]-[AXL.CLBR] Earth acc data updated (3661/15) [2025.11.24 17:53:36]-[REC.SEND.1] Modem not ready (try 30) [2025.11.24 17:53:37]-[AXL.CLBR] Earth acc data updated (3662/15) [2025.11.24 17:53:37]-[AXL.CLBR] Collecting AXL data! Cnt:3665 Straight:0 Ground:3662 [2025.11.24 17:53:37]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:53:38]-[AXL.CLBR] Earth acc data updated (3663/15) [2025.11.24 17:53:38]-[OVERSPD] Scenario disabled! [2025.11.24 17:53:38]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:181 Limit:1800 [2025.11.24 17:53:38]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1280 Limit:5400* [2025.11.24 17:53:38]-[REC.SEND.1] Modem not ready (try 29) [2025.11.24 17:53:39]-[AXL.CLBR] Earth acc data updated (3664/15) [2025.11.24 17:53:40]-[AXL.CLBR] Earth acc data updated (3665/15) [2025.11.24 17:53:40]-[REC.SEND.1] Modem not ready (try 28) [2025.11.24 17:53:41]-[AXL.CLBR] Earth acc data updated (3666/15) [2025.11.24 17:53:42]-[AXL.CLBR] Earth acc data updated (3667/15) [2025.11.24 17:53:42]-[AXL.CLBR] Collecting AXL data! Cnt:3670 Straight:0 Ground:3667 [2025.11.24 17:53:42]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 114 / 120 [2025.11.24 17:53:42]-[REC.SEND.1] Modem not ready (try 27) [2025.11.24 17:53:43]-[AXL.CLBR] Earth acc data updated (3668/15) [2025.11.24 17:53:44]-[AXL.CLBR] Earth acc data updated (3669/15) [2025.11.24 17:53:44]-[REC.SEND.1] Modem not ready (try 26) [2025.11.24 17:53:45]-[AXL.CLBR] Earth acc data updated (3670/15) [2025.11.24 17:53:46]-[AXL.CLBR] Earth acc data updated (3671/15) [2025.11.24 17:53:46]-[REC.SEND.1] Modem not ready (try 25) [2025.11.24 17:53:47]-[AXL.CLBR] Earth acc data updated (3672/15) [2025.11.24 17:53:47]-[AXL.CLBR] Collecting AXL data! Cnt:3675 Straight:0 Ground:3672 [2025.11.24 17:53:47]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:53:48]-[AXL.CLBR] Earth acc data updated (3673/15) [2025.11.24 17:53:48]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:53:48]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:53:48]-[ATCMD] <<AT+CPAS [2025.11.24 17:53:48]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:53:48]-[ATCMD] >>[134] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+CIMI [2025.11.24 17:53:48]-[OVERSPD] Scenario disabled! [2025.11.24 17:53:48]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:53:48]-[ATCMD] >>[172] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+CGREG? [2025.11.24 17:53:48]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:53:48]-[AT.RSP] Status: 4 [2025.11.24 17:53:48]-[AT.RSP] Unknown [2025.11.24 17:53:48]-[ATCMD] >>[140] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+CEREG? [2025.11.24 17:53:48]-[ATCMD] >>[141] +CEREG: 2,3 [2025.11.24 17:53:48]-[ATCMD] >>[141] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+QGMR [2025.11.24 17:53:48]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:53:48]-[ATCMD] >>[167] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+QCSQ [2025.11.24 17:53:48]-[ATCMD] >>[132] +QCSQ: “eMTC”,-83,-119,50,-20 [2025.11.24 17:53:48]-[AT.RSP] #RAT: “eMTC” [2025.11.24 17:53:48]-[AT.RSP] #RSSI: -83 dBm [2025.11.24 17:53:48]-[AT.RSP] #RSRP: -119 dBm [2025.11.24 17:53:48]-[AT.RSP] #SINR: -10.0 dB [2025.11.24 17:53:48]-[AT.RSP] #RSRQ: -20 dB [2025.11.24 17:53:48]-[ATCMD] >>[132] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:53:48]-[ATCMD] >>[133] +QNWINFO: “eMTC”,“310410”,“LTE BAND 12”,5110 [2025.11.24 17:53:48]-[ATCMD] >>[133] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+CSQ [2025.11.24 17:53:48]-[ATCMD] >>[131] +CSQ: 15,99 [2025.11.24 17:53:48]-[ATCMD] >>[131] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+CFUN? [2025.11.24 17:53:48]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:53:48]-[ATCMD] >>[151] OK [2025.11.24 17:53:48]-[ATCMD] <<AT+COPS? [2025.11.24 17:53:48]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:53:48]-[ATCMD] >>[135] OK [2025.11.24 17:53:48]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:53:48]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:59/81 [2025.11.24 17:53:48]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:191 Limit:1800 [2025.11.24 17:53:48]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1290 Limit:5400* [2025.11.24 17:53:48]-[REC.SEND.1] Modem not ready (try 24) [2025.11.24 17:53:49]-[AXL.CLBR] Earth acc data updated (3674/15) [2025.11.24 17:53:50]-[AXL.CLBR] Earth acc data updated (3675/15) [2025.11.24 17:53:50]-[SYS.DIAG] Code Version:04.00.00 Code Rev:13 IMEI: 862406076295233 HW ver: FMM920 HW mod: 1 HW volt:554mV HW tbl: 8 BL ver: 1.10 BLE: 1 NAND: 1 AXL: 1/LIS3DH BT ADDR:{38:8A:21:C3:E1:EB} Started:2025-11-24 16:51 Uptime: 0d 1h 2min 2s PWR rsn:SoftReset Cnt:0 Abn:0 Mode:Unknown on Stop SpcId:1 UpdRes:-65536 Calib: Empty Run: 1 Qual: 0.00 Dbg: 0 Iter: 3679,0 G{0.000000;0.000000;0.000000} R{0.000000;0.000000;0.000000} MAP{0.000000;0.000000;0.000000} DynZ{0.018890;-0.021446;1.041536} GPS Fix: 1 No fix reason: 0 GPS state: 1 TTFF: 8s TTLF: 5s NoFix: 0s Latitude :47.342925 Longitude:-122.105845 Altitude :145 FW Ver: AXN_5.1.9 SN mode: 1 TSYNC: Last Sync:GPS at 1763997456s, NTP cnt:0, Fails:0 [2025.11.24 17:53:50]-[REC.SEND.1] Modem not ready (try 23) [2025.11.24 17:53:51]-[AXL.CLBR] Earth acc data updated (3676/15) [2025.11.24 17:53:52]-[AXL.CLBR] Earth acc data updated (3677/15) [2025.11.24 17:53:52]-[AXL.CLBR] Collecting AXL data! Cnt:3680 Straight:0 Ground:3677 [2025.11.24 17:53:52]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 4 / 120 [2025.11.24 17:53:52]-[REC.SEND.1] Modem not ready (try 22) [2025.11.24 17:53:53]-[AXL.CLBR] Earth acc data updated (3678/15) [2025.11.24 17:53:54]-[AXL.CLBR] Earth acc data updated (3679/15) [2025.11.24 17:53:54]-[REC.SEND.1] Modem not ready (try 21) [2025.11.24 17:53:55]-[AXL.CLBR] Earth acc data updated (3680/15) [2025.11.24 17:53:56]-[AXL.CLBR] Earth acc data updated (3681/15) [2025.11.24 17:53:56]-[REC.SEND.1] Modem not ready (try 20) [2025.11.24 17:53:57]-[AXL.CLBR] Earth acc data updated (3682/15) [2025.11.24 17:53:57]-[AXL.CLBR] Collecting AXL data! Cnt:3685 Straight:0 Ground:3682 [2025.11.24 17:53:57]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:53:57]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:53:57]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13917 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:53:58]-[AXL.CLBR] Earth acc data updated (3683/15) [2025.11.24 17:53:58]-[OVERSPD] Scenario disabled! [2025.11.24 17:53:58]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:201 Limit:1800 [2025.11.24 17:53:58]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1300 Limit:5400* [2025.11.24 17:53:58]-[REC.SEND.1] Modem not ready (try 19) [2025.11.24 17:53:59]-[AXL.CLBR] Earth acc data updated (3684/15) [2025.11.24 17:54:00]-[AXL.CLBR] Earth acc data updated (3685/15) [2025.11.24 17:54:00]-[REC.SEND.1] Modem not ready (try 18) [2025.11.24 17:54:01]-[AXL.CLBR] Earth acc data updated (3686/15) [2025.11.24 17:54:02]-[AXL.CLBR] Earth acc data updated (3687/15) [2025.11.24 17:54:02]-[AXL.CLBR] Collecting AXL data! Cnt:3690 Straight:0 Ground:3687 [2025.11.24 17:54:02]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 14 / 120 [2025.11.24 17:54:02]-[REC.SEND.1] Modem not ready (try 17) [2025.11.24 17:54:03]-[AXL.CLBR] Earth acc data updated (3688/15) [2025.11.24 17:54:04]-[AXL.CLBR] Earth acc data updated (3689/15) [2025.11.24 17:54:04]-[REC.SEND.1] Modem not ready (try 16) [2025.11.24 17:54:05]-[AXL.CLBR] Earth acc data updated (3690/15) [MODEM.STATUS] CCID : 8942310223002516340 IMSI : 295050915745634 Data Link : 0/0/0/0/0/0 GPRS Status : 0 Phone Status: 0 PIN Attempts : 3,3 GSM Operator: 0 Bat. Charge : 0 GSM Signal : 4 Service : 0 New Message : 0 Roaming : 0 SMS Full : 0 Voice Call : 0 LAC : 0 Cell ID : 0 CFUN : 1 CSQ (rssi) : 15 QCSQ (rssi) : -83 dBm QCSQ (rsrp) : -119 dBm QCSQ (sinr) : -10.0 dB QCSQ (rsrq) : -20 dB [0]SIM detected: 1 Network Type: 99/UNKNOWN Current LTE BAND: 12 Modem (Relative / Absolute): StPin fails : 0 / 0 AT dead cnt : 0 / 0 Init fails : 0 / 0 [2025.11.24 17:54:06]-[AXL.CLBR] Earth acc data updated (3691/15) [2025.11.24 17:54:06]-[REC.SEND.1] Modem not ready (try 15) [2025.11.24 17:54:07]-[AXL.CLBR] Earth acc data updated (3692/15) [2025.11.24 17:54:07]-[AXL.CLBR] Collecting AXL data! Cnt:3695 Straight:0 Ground:3692 [2025.11.24 17:54:07]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:54:08]-[AXL.CLBR] Earth acc data updated (3693/15) [2025.11.24 17:54:08]-[OVERSPD] Scenario disabled! [2025.11.24 17:54:08]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:211 Limit:1800 [2025.11.24 17:54:08]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1310 Limit:5400* [2025.11.24 17:54:08]-[REC.SEND.1] Modem not ready (try 14) [2025.11.24 17:54:09]-[AXL.CLBR] Earth acc data updated (3694/15) [2025.11.24 17:54:10]-[AXL.CLBR] Earth acc data updated (3695/15) [2025.11.24 17:54:10]-[REC.SEND.1] Modem not ready (try 13) [2025.11.24 17:54:11]-[AXL.CLBR] Earth acc data updated (3696/15) [2025.11.24 17:54:12]-[AXL.CLBR] Earth acc data updated (3697/15) [2025.11.24 17:54:12]-[AXL.CLBR] Collecting AXL data! Cnt:3700 Straight:0 Ground:3697 [2025.11.24 17:54:12]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 24 / 120 [2025.11.24 17:54:12]-[REC.SEND.1] Modem not ready (try 12) [2025.11.24 17:54:13]-[AXL.CLBR] Earth acc data updated (3698/15) [2025.11.24 17:54:14]-[AXL.CLBR] Earth acc data updated (3699/15) [2025.11.24 17:54:14]-[REC.SEND.1] Modem not ready (try 11) [2025.11.24 17:54:15]-[AXL.CLBR] Earth acc data updated (3700/15) [2025.11.24 17:54:16]-[AXL.CLBR] Earth acc data updated (3701/15) [2025.11.24 17:54:16]-[REC.SEND.1] Modem not ready (try 10) [2025.11.24 17:54:17]-[AXL.CLBR] Earth acc data updated (3702/15) [2025.11.24 17:54:17]-[AXL.CLBR] Collecting AXL data! Cnt:3705 Straight:0 Ground:3702 [2025.11.24 17:54:17]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:54:18]-[AXL.CLBR] Earth acc data updated (3703/15) [2025.11.24 17:54:18]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:54:18]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:54:18]-[ATCMD] <<AT+CPAS [2025.11.24 17:54:18]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:54:18]-[ATCMD] >>[134] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+CIMI [2025.11.24 17:54:18]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:54:18]-[ATCMD] >>[172] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+CGREG? [2025.11.24 17:54:18]-[OVERSPD] Scenario disabled! [2025.11.24 17:54:18]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:54:18]-[AT.RSP] Status: 4 [2025.11.24 17:54:18]-[AT.RSP] Unknown [2025.11.24 17:54:18]-[ATCMD] >>[140] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+CEREG? [2025.11.24 17:54:18]-[ATCMD] >>[141] +CEREG: 2,3 [2025.11.24 17:54:18]-[ATCMD] >>[141] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+QGMR [2025.11.24 17:54:18]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:54:18]-[ATCMD] >>[167] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+QCSQ [2025.11.24 17:54:18]-[ATCMD] >>[132] +QCSQ: “eMTC”,-83,-119,56,-20 [2025.11.24 17:54:18]-[AT.RSP] #RAT: “eMTC” [2025.11.24 17:54:18]-[AT.RSP] #RSSI: -83 dBm [2025.11.24 17:54:18]-[AT.RSP] #RSRP: -119 dBm [2025.11.24 17:54:18]-[AT.RSP] #SINR: -8.8 dB [2025.11.24 17:54:18]-[AT.RSP] #RSRQ: -20 dB [2025.11.24 17:54:18]-[ATCMD] >>[132] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:54:18]-[ATCMD] >>[133] +QNWINFO: “eMTC”,“310410”,“LTE BAND 12”,5110 [2025.11.24 17:54:18]-[ATCMD] >>[133] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+CSQ [2025.11.24 17:54:18]-[ATCMD] >>[131] +CSQ: 15,99 [2025.11.24 17:54:18]-[ATCMD] >>[131] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+CFUN? [2025.11.24 17:54:18]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:54:18]-[ATCMD] >>[151] OK [2025.11.24 17:54:18]-[ATCMD] <<AT+COPS? [2025.11.24 17:54:18]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:54:18]-[ATCMD] >>[135] OK [2025.11.24 17:54:18]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:54:18]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:60/81 [2025.11.24 17:54:18]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:221 Limit:1800 [2025.11.24 17:54:18]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1320 Limit:5400* [2025.11.24 17:54:18]-[REC.SEND.1] Modem not ready (try 9) [2025.11.24 17:54:19]-[AXL.CLBR] Earth acc data updated (3704/15) [2025.11.24 17:54:20]-[AXL.CLBR] Earth acc data updated (3705/15) [2025.11.24 17:54:20]-[BLE.APP] bt init: 1, ble init: 1, sens en: 0, cnt: 0/30, listen: 1, broadcast: 1/0x0000 [2025.11.24 17:54:20]-[BLE.APP] [00] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:54:20]-[BLE.APP] [01] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:54:20]-[BLE.APP] [02] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:54:20]-[BLE.APP] [03] connected: 0, target addr: 00:00:00:00:00:00 [2025.11.24 17:54:20]-[BLE.APP] ble scan status: 0, caller status: 0/?, unlimited: 0 [2025.11.24 17:54:20]-[REC.SEND.1] Modem not ready (try 8) [2025.11.24 17:54:21]-[AXL.CLBR] Earth acc data updated (3706/15) [2025.11.24 17:54:22]-[AXL.CLBR] Earth acc data updated (3707/15) [2025.11.24 17:54:22]-[AXL.CLBR] Collecting AXL data! Cnt:3710 Straight:0 Ground:3707 [2025.11.24 17:54:22]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 34 / 120 [2025.11.24 17:54:22]-[REC.SEND.1] Modem not ready (try 7) [2025.11.24 17:54:23]-[AXL.CLBR] Earth acc data updated (3708/15) [2025.11.24 17:54:24]-[AXL.CLBR] Earth acc data updated (3709/15) [2025.11.24 17:54:24]-[REC.SEND.1] Modem not ready (try 6) [2025.11.24 17:54:25]-[AXL.CLBR] Earth acc data updated (3710/15) [2025.11.24 17:54:26]-[AXL.CLBR] Earth acc data updated (3711/15) [2025.11.24 17:54:26]-[REC.SEND.1] Modem not ready (try 5) [2025.11.24 17:54:27]-[AXL.CLBR] Earth acc data updated (3712/15) [2025.11.24 17:54:27]-[AXL.CLBR] Collecting AXL data! Cnt:3715 Straight:0 Ground:3712 [2025.11.24 17:54:27]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:54:27]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:54:27]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13908 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:54:28]-[AXL.CLBR] Earth acc data updated (3713/15) [2025.11.24 17:54:28]-[OVERSPD] Scenario disabled! [2025.11.24 17:54:28]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:231 Limit:1800 [2025.11.24 17:54:28]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1330 Limit:5400* [2025.11.24 17:54:28]-[REC.SEND.1] Modem not ready (try 4) [2025.11.24 17:54:29]-[AXL.CLBR] Earth acc data updated (3714/15) [2025.11.24 17:54:30]-[AXL.CLBR] Earth acc data updated (3715/15) [2025.11.24 17:54:30]-[REC.SEND.1] Modem not ready (try 3) [2025.11.24 17:54:31]-[AXL.CLBR] Earth acc data updated (3716/15) [2025.11.24 17:54:32]-[AXL.CLBR] Earth acc data updated (3717/15) [2025.11.24 17:54:32]-[AXL.CLBR] Collecting AXL data! Cnt:3720 Straight:0 Ground:3717 [2025.11.24 17:54:32]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 44 / 120 [2025.11.24 17:54:32]-[REC.SEND.1] Modem not ready (try 2) [2025.11.24 17:54:33]-[AXL.CLBR] Earth acc data updated (3718/15) [2025.11.24 17:54:34]-[AXL.CLBR] Earth acc data updated (3719/15) [2025.11.24 17:54:34]-[REC.SEND.1] Modem not ready (try 1) [2025.11.24 17:54:35]-[AXL.CLBR] Earth acc data updated (3720/15) [2025.11.24 17:54:35]-[APN.LIST] AutoAPN save count: 0 [2025.11.24 17:54:35]-[GPS.TEST] [GPS.DATA] gps state: ON status FIX: 1 No fix reason: 0 moment RMC status: A moment GGA quality: 1 moment latitude: 47.342925, good latitude: 47.342925 moment longitude: -122.105845, good longitude: -122.105845 moment altitude: 145.900000, good altitude: 145.900000 moment speed: 0.000000, good speed: 0.000000 moment angle: 2.410000, good angle: 2.410000 moment gps sats in view/use: 10/8 moment galileo sats in view/use: 0/0 moment glonass sats in view/use: 8/5 moment beidou sats in view/use: 0/0 moment total GSV sats in view: 18 moment total GSA sats in use: 13 status time: 17:54:35 status date: 2025.11.24 GPS init status: 3 moment avg pdop: 1.420000 moment avg hdop: 0.780000 moment accuracy: 4.000000 fw version: MT3333_AXN_5.1.9_MT2503_STD_F0,0000, GNSS system: GPS GLONASS nmea data captured: 3773 nmea stability: 1 SN mode: 1 gps flashing: 0 version state: 3 [2025.11.24 17:54:36]-[AXL.CLBR] Earth acc data updated (3721/15) [2025.11.24 17:54:36]-[REC.SEND.1] Modem not ready (try 0) [2025.11.24 17:54:36]-[REC.SEND.1] [CHANGE.STATE.0548] Server: 0, check gprs => finished [2025.11.24 17:54:36]-[REC.SEND.1] finished [2025.11.24 17:54:37]-[AXL.CLBR] Earth acc data updated (3722/15) [2025.11.24 17:54:37]-[AXL.CLBR] Collecting AXL data! Cnt:3725 Straight:0 Ground:3722 [2025.11.24 17:54:37]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:54:38]-[AXL.CLBR] Earth acc data updated (3723/15) [2025.11.24 17:54:38]-[OVERSPD] Scenario disabled! [2025.11.24 17:54:38]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:241 Limit:1800 [2025.11.24 17:54:38]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1340 Limit:5400* [2025.11.24 17:54:39]-[AXL.CLBR] Earth acc data updated (3724/15) [2025.11.24 17:54:40]-[AXL.CLBR] Earth acc data updated (3725/15) [2025.11.24 17:54:41]-[AXL.CLBR] Earth acc data updated (3726/15) [2025.11.24 17:54:42]-[AXL.CLBR] Earth acc data updated (3727/15) [2025.11.24 17:54:42]-[AXL.CLBR] Collecting AXL data! Cnt:3730 Straight:0 Ground:3727 [2025.11.24 17:54:42]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 54 / 120 [2025.11.24 17:54:43]-[AXL.CLBR] Earth acc data updated (3728/15) [2025.11.24 17:54:44]-[AXL.CLBR] Earth acc data updated (3729/15) [2025.11.24 17:54:45]-[AXL.CLBR] Earth acc data updated (3730/15) [2025.11.24 17:54:46]-[AXL.CLBR] Earth acc data updated (3731/15) [2025.11.24 17:54:46]-[ATCMD] >>[227] +CEREG: 2 [2025.11.24 17:54:47]-[AXL.CLBR] Earth acc data updated (3732/15) [2025.11.24 17:54:47]-[AXL.CLBR] Collecting AXL data! Cnt:3735 Straight:0 Ground:3732 [2025.11.24 17:54:47]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:54:48]-[AXL.CLBR] Earth acc data updated (3733/15) [2025.11.24 17:54:48]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:54:48]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:54:48]-[ATCMD] <<AT+CPAS [2025.11.24 17:54:48]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:54:48]-[ATCMD] >>[134] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+CIMI [2025.11.24 17:54:48]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:54:48]-[ATCMD] >>[172] OK [2025.11.24 17:54:48]-[OVERSPD] Scenario disabled! [2025.11.24 17:54:48]-[ATCMD] <<AT+CGREG? [2025.11.24 17:54:48]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:54:48]-[AT.RSP] Status: 4 [2025.11.24 17:54:48]-[AT.RSP] Unknown [2025.11.24 17:54:48]-[ATCMD] >>[140] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+CEREG? [2025.11.24 17:54:48]-[ATCMD] >>[141] +CEREG: 2,2 [2025.11.24 17:54:48]-[ATCMD] >>[141] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+QGMR [2025.11.24 17:54:48]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:54:48]-[ATCMD] >>[167] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+QCSQ [2025.11.24 17:54:48]-[ATCMD] >>[132] +QCSQ: “eMTC”,-83,-118,51,-20 [2025.11.24 17:54:48]-[AT.RSP] #RAT: “eMTC” [2025.11.24 17:54:48]-[AT.RSP] #RSSI: -83 dBm [2025.11.24 17:54:48]-[AT.RSP] #RSRP: -118 dBm [2025.11.24 17:54:48]-[AT.RSP] #SINR: -9.8 dB [2025.11.24 17:54:48]-[AT.RSP] #RSRQ: -20 dB [2025.11.24 17:54:48]-[ATCMD] >>[132] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:54:48]-[ATCMD] >>[133] +QNWINFO: “eMTC”,“310410”,“LTE BAND 12”,5110 [2025.11.24 17:54:48]-[ATCMD] >>[133] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+CSQ [2025.11.24 17:54:48]-[ATCMD] >>[131] +CSQ: 15,99 [2025.11.24 17:54:48]-[ATCMD] >>[131] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+CFUN? [2025.11.24 17:54:48]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:54:48]-[ATCMD] >>[151] OK [2025.11.24 17:54:48]-[ATCMD] <<AT+COPS? [2025.11.24 17:54:48]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:54:48]-[ATCMD] >>[135] OK [2025.11.24 17:54:48]-[REC.SEND.1] Caller: 0718, queueing recsend1 task job type: 6/force open link [2025.11.24 17:54:48]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:54:48]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:61/81 [2025.11.24 17:54:48]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:251 Limit:1800 [2025.11.24 17:54:48]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1350 Limit:5400* [2025.11.24 17:54:48]-[REC.SEND.1] [CHANGE.STATE.0276] Server: 0, finished => check gprs [2025.11.24 17:54:48]-[REC.SEND.1] check gprs [2025.11.24 17:54:48]-[REC.SEND.1] Modem not ready (try 69) [2025.11.24 17:54:49]-[AXL.CLBR] Earth acc data updated (3734/15) [2025.11.24 17:54:50]-[AXL.CLBR] Earth acc data updated (3735/15) [2025.11.24 17:54:50]-[OBDII] OBD Disabled (1 0) [2025.11.24 17:54:50]-[REC.SEND.1] Modem not ready (try 68) [2025.11.24 17:54:51]-[AXL.CLBR] Earth acc data updated (3736/15) [2025.11.24 17:54:52]-[AXL.CLBR] Earth acc data updated (3737/15) [2025.11.24 17:54:52]-[AXL.CLBR] Collecting AXL data! Cnt:3740 Straight:0 Ground:3737 [2025.11.24 17:54:52]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 64 / 120 [2025.11.24 17:54:52]-[REC.SEND.1] Modem not ready (try 67) [2025.11.24 17:54:53]-[AXL.CLBR] Earth acc data updated (3738/15) [2025.11.24 17:54:54]-[AXL.CLBR] Earth acc data updated (3739/15) [2025.11.24 17:54:54]-[REC.SEND.1] Modem not ready (try 66) [2025.11.24 17:54:55]-[AXL.CLBR] Earth acc data updated (3740/15) [2025.11.24 17:54:56]-[AXL.CLBR] Earth acc data updated (3741/15) [2025.11.24 17:54:56]-[REC.SEND.1] Modem not ready (try 65) [2025.11.24 17:54:57]-[AXL.CLBR] Earth acc data updated (3742/15) [2025.11.24 17:54:57]-[AXL.CLBR] Collecting AXL data! Cnt:3745 Straight:0 Ground:3742 [2025.11.24 17:54:57]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:54:57]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:54:57]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13915 BatV: 4114 BatI: 0 Bat%: 100 [2025.11.24 17:54:58]-[AXL.CLBR] Earth acc data updated (3743/15) [2025.11.24 17:54:58]-[OVERSPD] Scenario disabled! [2025.11.24 17:54:58]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:261 Limit:1800 [2025.11.24 17:54:58]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1360 Limit:5400* [2025.11.24 17:54:58]-[REC.SEND.1] Modem not ready (try 64) [2025.11.24 17:54:59]-[AXL.CLBR] Earth acc data updated (3744/15) [2025.11.24 17:55:00]-[AXL.CLBR] Earth acc data updated (3745/15) [2025.11.24 17:55:00]-[REC.SEND.1] Modem not ready (try 63) [2025.11.24 17:55:01]-[AXL.CLBR] Earth acc data updated (3746/15) [2025.11.24 17:55:02]-[AXL.CLBR] Earth acc data updated (3747/15) [2025.11.24 17:55:02]-[AXL.CLBR] Collecting AXL data! Cnt:3750 Straight:0 Ground:3747 [2025.11.24 17:55:02]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 74 / 120 [2025.11.24 17:55:02]-[REC.SEND.1] Modem not ready (try 62) [2025.11.24 17:55:03]-[AXL.CLBR] Earth acc data updated (3748/15) [2025.11.24 17:55:04]-[AXL.CLBR] Earth acc data updated (3749/15) [2025.11.24 17:55:04]-[REC.SEND.1] Modem not ready (try 61) [2025.11.24 17:55:05]-[AXL.CLBR] Earth acc data updated (3750/15) [2025.11.24 17:55:05]-[ADC] Values Table: [Core V ]: 1.000 (3865) 0 [External V]: 16.000 (13915) 470 [Battery V ]: 1.727 (4114) 0 [Ch. current]: 0.071 (0) 0 [Ain1 ]: 16.000 (0) 0 [NTC ]: 1.000 (1752) 0 Using Conv Table:FMB9XX CalibVals:1 [2025.11.24 17:55:06]-[AXL.CLBR] Earth acc data updated (3751/15) [2025.11.24 17:55:06]-[REC.SEND.1] Modem not ready (try 60) [2025.11.24 17:55:07]-[AXL.CLBR] Earth acc data updated (3752/15) [2025.11.24 17:55:07]-[AXL.CLBR] Collecting AXL data! Cnt:3755 Straight:0 Ground:3752 [2025.11.24 17:55:07]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:55:08]-[AXL.CLBR] Earth acc data updated (3753/15) [2025.11.24 17:55:08]-[OVERSPD] Scenario disabled! [2025.11.24 17:55:08]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:271 Limit:1800 [2025.11.24 17:55:08]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1370 Limit:5400* [2025.11.24 17:55:08]-[REC.SEND.1] Modem not ready (try 59) [2025.11.24 17:55:09]-[AXL.CLBR] Earth acc data updated (3754/15) [2025.11.24 17:55:10]-[AXL.CLBR] Earth acc data updated (3755/15) [2025.11.24 17:55:10]-[REC.SEND.1] Modem not ready (try 58) [2025.11.24 17:55:11]-[AXL.CLBR] Earth acc data updated (3756/15) [2025.11.24 17:55:12]-[AXL.CLBR] Earth acc data updated (3757/15) [2025.11.24 17:55:12]-[AXL.CLBR] Collecting AXL data! Cnt:3760 Straight:0 Ground:3757 [2025.11.24 17:55:12]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 84 / 120 [2025.11.24 17:55:12]-[REC.SEND.1] Modem not ready (try 57) [2025.11.24 17:55:13]-[AXL.CLBR] Earth acc data updated (3758/15) [2025.11.24 17:55:14]-[AXL.CLBR] Earth acc data updated (3759/15) [2025.11.24 17:55:14]-[REC.SEND.1] Modem not ready (try 56) [2025.11.24 17:55:15]-[AXL.CLBR] Earth acc data updated (3760/15) [2025.11.24 17:55:16]-[AXL.CLBR] Earth acc data updated (3761/15) [2025.11.24 17:55:16]-[REC.SEND.1] Modem not ready (try 55) [2025.11.24 17:55:17]-[AXL.CLBR] Earth acc data updated (3762/15) [2025.11.24 17:55:17]-[AXL.CLBR] Collecting AXL data! Cnt:3765 Straight:0 Ground:3762 [2025.11.24 17:55:17]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:55:18]-[AXL.CLBR] Earth acc data updated (3763/15) [2025.11.24 17:55:18]-[MODEM.ST] AT dead RSNs: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 [2025.11.24 17:55:18]-[MODEM.ACTION] GSM Update Reason:Periodic [2025.11.24 17:55:18]-[ATCMD] <<AT+CPAS [2025.11.24 17:55:18]-[ATCMD] >>[134] +CPAS: 0 [2025.11.24 17:55:18]-[ATCMD] >>[134] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+CIMI [2025.11.24 17:55:18]-[ATCMD] >>[172] 295050915745634 [2025.11.24 17:55:18]-[ATCMD] >>[172] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+CGREG? [2025.11.24 17:55:18]-[OVERSPD] Scenario disabled! [2025.11.24 17:55:18]-[ATCMD] >>[140] +CGREG: 2,4 [2025.11.24 17:55:18]-[AT.RSP] Status: 4 [2025.11.24 17:55:18]-[AT.RSP] Unknown [2025.11.24 17:55:18]-[ATCMD] >>[140] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+CEREG? [2025.11.24 17:55:18]-[ATCMD] >>[141] +CEREG: 2,2 [2025.11.24 17:55:18]-[ATCMD] >>[141] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+QGMR [2025.11.24 17:55:18]-[ATCMD] >>[167] BG95M3LAR02A03_01.012.01.012 [2025.11.24 17:55:18]-[ATCMD] >>[167] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+QCSQ [2025.11.24 17:55:18]-[ATCMD] >>[132] +QCSQ: “eMTC”,-85,-120,51,-20 [2025.11.24 17:55:18]-[AT.RSP] #RAT: “eMTC” [2025.11.24 17:55:18]-[AT.RSP] #RSSI: -85 dBm [2025.11.24 17:55:18]-[AT.RSP] #RSRP: -120 dBm [2025.11.24 17:55:18]-[AT.RSP] #SINR: -9.8 dB [2025.11.24 17:55:18]-[AT.RSP] #RSRQ: -20 dB [2025.11.24 17:55:18]-[ATCMD] >>[132] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+QNWINFO [2025.11.24 17:55:18]-[ATCMD] >>[133] +QNWINFO: “eMTC”,“310410”,“LTE BAND 12”,5110 [2025.11.24 17:55:18]-[ATCMD] >>[133] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+CSQ [2025.11.24 17:55:18]-[ATCMD] >>[131] +CSQ: 14,99 [2025.11.24 17:55:18]-[ATCMD] >>[131] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+CFUN? [2025.11.24 17:55:18]-[ATCMD] >>[151] +CFUN: 1 [2025.11.24 17:55:18]-[ATCMD] >>[151] OK [2025.11.24 17:55:18]-[ATCMD] <<AT+COPS? [2025.11.24 17:55:18]-[ATCMD] >>[135] +COPS: 0 [2025.11.24 17:55:18]-[ATCMD] >>[135] OK [2025.11.24 17:55:18]-[MODEM.ACTION] op wait tmo:2430s [2025.11.24 17:55:18]-[MODEM.ACTION] CNT CME_ERR:0, CME_ERR_R:0, OP_FAIL:62/81 [2025.11.24 17:55:18]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:281 Limit:1800 [2025.11.24 17:55:18]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1380 Limit:5400* [2025.11.24 17:55:18]-[REC.SEND.1] Modem not ready (try 54) [2025.11.24 17:55:19]-[AXL.CLBR] Earth acc data updated (3764/15) [2025.11.24 17:55:20]-[AXL.CLBR] Earth acc data updated (3765/15) [2025.11.24 17:55:20]-[SYS.DIAG] Code Version:04.00.00 Code Rev:13 IMEI: 862406076295233 HW ver: FMM920 HW mod: 1 HW volt:554mV HW tbl: 8 BL ver: 1.10 BLE: 1 NAND: 1 AXL: 1/LIS3DH BT ADDR:{38:8A:21:C3:E1:EB} Started:2025-11-24 16:51 Uptime: 0d 1h 3min 32s PWR rsn:SoftReset Cnt:0 Abn:0 Mode:Unknown on Stop SpcId:1 UpdRes:-65536 Calib: Empty Run: 1 Qual: 0.00 Dbg: 0 Iter: 3769,0 G{0.000000;0.000000;0.000000} R{0.000000;0.000000;0.000000} MAP{0.000000;0.000000;0.000000} DynZ{0.017933;-0.021898;1.041210} GPS Fix: 1 No fix reason: 0 GPS state: 1 TTFF: 8s TTLF: 5s NoFix: 0s Latitude :47.342925 Longitude:-122.105845 Altitude :145 FW Ver: AXN_5.1.9 SN mode: 1 TSYNC: Last Sync:GPS at 1763997456s, NTP cnt:0, Fails:0 [2025.11.24 17:55:20]-[REC.SEND.1] Modem not ready (try 53) [2025.11.24 17:55:21]-[AXL.CLBR] Earth acc data updated (3766/15) [2025.11.24 17:55:22]-[AXL.CLBR] Earth acc data updated (3767/15) [2025.11.24 17:55:22]-[AXL.CLBR] Collecting AXL data! Cnt:3770 Straight:0 Ground:3767 [2025.11.24 17:55:22]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 94 / 120 [2025.11.24 17:55:22]-[REC.SEND.1] Modem not ready (try 52) [2025.11.24 17:55:23]-[AXL.CLBR] Earth acc data updated (3768/15) [2025.11.24 17:55:24]-[AXL.CLBR] Earth acc data updated (3769/15) [2025.11.24 17:55:24]-[REC.SEND.1] Modem not ready (try 51) [2025.11.24 17:55:25]-[AXL.CLBR] Earth acc data updated (3770/15) [2025.11.24 17:55:26]-[AXL.CLBR] Earth acc data updated (3771/15) [2025.11.24 17:55:26]-[REC.SEND.1] Modem not ready (try 50) [2025.11.24 17:55:27]-[AXL.CLBR] Earth acc data updated (3772/15) [2025.11.24 17:55:27]-[AXL.CLBR] Collecting AXL data! Cnt:3775 Straight:0 Ground:3772 [2025.11.24 17:55:27]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition [2025.11.24 17:55:27]-[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 1, battery prot not active [2025.11.24 17:55:27]-[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 13908 BatV: 4113 BatI: 0 Bat%: 100 [2025.11.24 17:55:28]-[AXL.CLBR] Earth acc data updated (3773/15) [2025.11.24 17:55:28]-[OVERSPD] Scenario disabled! [2025.11.24 17:55:28]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:291 Limit:1800 [2025.11.24 17:55:28]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1390 Limit:5400* [2025.11.24 17:55:28]-[REC.SEND.1] Modem not ready (try 49) [2025.11.24 17:55:29]-[AXL.CLBR] Earth acc data updated (3774/15) [2025.11.24 17:55:30]-[AXL.CLBR] Earth acc data updated (3775/15) [2025.11.24 17:55:30]-[REC.SEND.1] Modem not ready (try 48) [2025.11.24 17:55:31]-[AXL.CLBR] Earth acc data updated (3776/15) [2025.11.24 17:55:32]-[AXL.CLBR] Earth acc data updated (3777/15) [2025.11.24 17:55:32]-[AXL.CLBR] Collecting AXL data! Cnt:3780 Straight:0 Ground:3777 [2025.11.24 17:55:32]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 104 / 120 [2025.11.24 17:55:32]-[REC.SEND.1] Modem not ready (try 47) [2025.11.24 17:55:33]-[AXL.CLBR] Earth acc data updated (3778/15) [2025.11.24 17:55:34]-[AXL.CLBR] Earth acc data updated (3779/15) [2025.11.24 17:55:34]-[REC.SEND.1] Modem not ready (try 46) [2025.11.24 17:55:35]-[AXL.CLBR] Earth acc data updated (3780/15) [MODEM.STATUS] CCID : 8942310223002516340 IMSI : 295050915745634 Data Link : 0/0/0/0/0/0 GPRS Status : 0 Phone Status: 0 PIN Attempts : 3,3 GSM Operator: 0 Bat. Charge : 0 GSM Signal : 3 Service : 0 New Message : 0 Roaming : 0 SMS Full : 0 Voice Call : 0 LAC : 0 Cell ID : 0 CFUN : 1 CSQ (rssi) : 14 QCSQ (rssi) : -85 dBm QCSQ (rsrp) : -120 dBm QCSQ (sinr) : -9.8 dB QCSQ (rsrq) : -20 dB [0]SIM detected: 1 Network Type: 99/UNKNOWN Current LTE BAND: 12 Modem (Relative / Absolute): StPin fails : 0 / 0 AT dead cnt : 0 / 0 Init fails : 0 / 0 [2025.11.24 17:55:36]-[AXL.CLBR] Earth acc data updated (3781/15)[2025.11.24 17:55:36]-[REC.SEND.1] Modem not ready (try 45)[2025.11.24 17:55:37]-[AXL.CLBR] Earth acc data updated (3782/15)[2025.11.24 17:55:37]-[AXL.CLBR] Collecting AXL data! Cnt:3785 Straight:0 Ground:3782[2025.11.24 17:55:37]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition[2025.11.24 17:55:38]-[AXL.CLBR] Earth acc data updated (3783/15)[2025.11.24 17:55:38]-[OVERSPD] Scenario disabled![2025.11.24 17:55:38]-[WD.FUNC] WARNING @ 239:[1] counter:0 Cnt:301 Limit:1800[2025.11.24 17:55:38]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:1400 Limit:5400*[2025.11.24 17:55:38]-[REC.SEND.1] Modem not ready (try 44)[2025.11.24 17:55:39]-[AXL.CLBR] Earth acc data updated (3784/15)[2025.11.24 17:55:40]-[AXL.CLBR] Earth acc data updated (3785/15)[2025.11.24 17:55:40]-[REC.SEND.1] Modem not ready (try 43)[2025.11.24 17:55:41]-[AXL.CLBR] Earth acc data updated (3786/15)[2025.11.24 17:55:42]-[AXL.CLBR] Earth acc data updated (3787/15)[2025.11.24 17:55:42]-[AXL.CLBR] Collecting AXL data! Cnt:3790 Straight:0 Ground:3787[2025.11.24 17:55:42]-[REC.SEND.1] Mode: 4/Unknown on Stop. Next periodic data sending: 114 / 120[2025.11.24 17:55:42]-[REC.SEND.1] Modem not ready (try 42)[2025.11.24 17:55:43]-[AXL.CLBR] Earth acc data updated (3788/15)[2025.11.24 17:55:44]-[AXL.CLBR] Earth acc data updated (3789/15)[2025.11.24 17:55:44]-[REC.SEND.1] Modem not ready (try 41)[2025.11.24 17:55:45]-[AXL.CLBR] Earth acc data updated (3790/15)[2025.11.24 17:55:46]-[AXL.CLBR] Earth acc data updated (3791/15)[2025.11.24 17:55:46]-[REC.SEND.1] Modem not ready (try 40)[2025.11.24 17:55:47]-[AXL.CLBR] Earth acc data updated (3792/15)[2025.11.24 17:55:47]-[AXL.CLBR] Collecting AXL data! Cnt:3795 Straight:0 Ground:3792[2025.11.24 17:55:47]-[SLEEP] WARNING @ 287:Sleep:3, not allowed! Reason:Ignition[2025.11.24 17:55:48]-[AXL.CLBR] Earth acc data updated (3793/15)fwef
I also can’t paste a clean log because it says “new users can only post 2 links per post” even I put the log in a text snippet box. So I had to make it a link, sorry!
I’m having the same issue but with my FMM130. I’m planning to switch to Soracom as well. Any updates?
I had some success disabling NB-IOT and locking it to AT&T, but it hasn’t been perfect. I have yet to install it and see how it works in the field. It appears to be latching on a distant, NB-IOT signal that is barely usable in my correspondence with Soracom rather than the good AT&T one.
